It is currently Fri Nov 13, 2026 5:21 pm
Post Posted: Sun Nov 21, 2010 5:34 am
well after seeing a very well done home made sand flag on the weekend, i decided to make one..
first i bought a 9.5 mm tent pole, the fiberglass type that connect to gether to slide through the tent..
then i bought a copule of air fittings... messed around for a bit and came up with this..
ill bolt the male fitting through the plate on my bull bar. quick release flag, that folds up smaller than any bought flag, for a fraction of the price..
Download Sets @ http://www.johnpaul.3leggedcat.net
Vehicle: '96 LWB trayback
Post Posted: Sun Nov 21, 2010 5:41 am
Nice idea with the pneumatic coupling. Thats using your head.
Post Posted: Sun Nov 21, 2010 5:43 am
nah i cant take credit for the idea.. just thought i'd share with others as its a fair bit cheaper than buying a pre made flag.. and a hell of a lot smaller when you pack it away..
Post Posted: Sun Nov 21, 2010 10:07 am
very good idea with the air fittings, ill be using that.
one question tho, how are the lengths of pipe being held together? as the tent poles i have seen will disconnect with a slight pull, so once you get up to speed or go over a bump wont they just disconnect from each other?
Mitch
Post Posted: Sun Nov 21, 2010 10:14 am
I don't think it will be an issue with just the bouncing around. Just an idea though, when you are home and you are storing it you will be way better off straightening it out and storing it like that as the elastic is less stretched when it is straight so it might last longer.
the person i coppied the idea from told me he has had them on the rig for 4 days strait and they were fine. the elastic that holds them together is quite strong depending on how tight you make it, and any movement (wind pulling them backwards) seems to make them hard to pull apart.. i followed him up the top of saunders gorge and it was very windy and it held up great.. he has the tent/flag pole going through a ring about 20cm from the base to give it more stability and strength.
as for the air fitting, the flags you buy from ARB have the same idea. although the flag is close to $100 + $25 for the quick release air fitting attachment + $25 for a spring on the base.
this so far cost me $5 for the flag, $19 for the tent pole, and $10 for the air fittings.. and from what i have seen, will do just as well, if not better as it folds up much smaller..
Post Posted: Sun Nov 21, 2010 11:07 am
you only need a sand flag on vehicles that move in the dunes... since you bought a land rover, it will either be broken or bogged... hence, no need for a sand flag :wink: :finger:
Go Hard, Trailer Home
Post Posted: Sun Nov 21, 2010 11:09 am
oh thats not very nice.. you hurt my feelings.. my landrover did quite well on the sand this last weekend actually.. up dunes the "prado point" boys were having trouble with.. :-) im not scared to use it, especially when it comes to showing up the bigger boys..
Post Posted: Mon Nov 22, 2010 3:26 am
Thanks morpheus for the idea..
i just made mine... not as flash as yours.. but managed it for $2.30 and 4 zip ties..
same idea for pole, shorted 2 lengths out of it.. so its around 7ft..
used a bunnings long load flag cut into a triangle
and zip tied it to the front of my chassis :D
looks well average :D but will do the job
Post Posted: Mon Nov 22, 2010 7:46 am
so long as it does the job, and prevents someone landing on top of you on the sand dunes, it dont matter what it looks like.. i just mounted mine to the car and took it for a spin.. i got up to 80K's and it looked fine.... i put 2 sockets on the bull bar so i'd have a choice of where i wanted it.. in the middle of the bull bar, or in front of the left hand headlight..
Post Posted: Mon Nov 22, 2010 7:54 am
Nice idea, how does the female air fitting attach to the tent pole ?
Post Posted: Mon Nov 22, 2010 7:57 am
its a barbed end, and i just pushed it in, when i say pushed, i actually mean hit it on the floor til it went in lol.. its unlikely i'll ever be able to pull it out, let alone fall out.... the tent poles i used were 9'5mm, and the barbed female end is made for a 10mm air pipe, so its almost a perfect fit..
Post Posted: Mon Nov 22, 2010 8:20 am
nice work JP, that looks better than a bought one.... now where do the PanterA patented sand flag LED's attach to?
Post Posted: Mon Nov 22, 2010 8:48 am
i haven't even seen his LED attachment.... looks like i might have to make up something special..
Post Posted: Mon Nov 22, 2010 8:59 am
Worked out well :wink: What sandhills were you doin 80km in?
And ya dont need a flag at goolwa :lol:
Post Posted: Mon Nov 22, 2010 9:16 am
i did 80K's on the street just to see how it went with a load of wind on it. see how far it bent backwards..
may not need it at goolwa. but im pretty sure im gonna need it @ some stage..
had nothing to do sunday and made that..
Post Posted: Mon Nov 22, 2010 9:19 am
I'm only stirring :wink:
Its better than my $5 minda trike flag :rofl:
Post Posted: Mon Nov 22, 2010 9:21 am
HAHA... hey i have 2 of those minda trike flags.. i was gonna put em either side of the back of my camper trailer.. but then i thought better of it.. lol..
Post Posted: Mon Nov 22, 2010 9:22 am
you're a prick, that poor bloke is still riding his trike around the craigburn minda farm with no flag... :lol:
Vehicle: 91 sierra
Post Posted: Mon Jan 03, 2011 3:44 am
i made a sand flag using a old beach fishing rod, stripped of the eyelets for the fishing wire to go through, spayed the pole black, then mounted a peice of pvc conduit to the bull bar and hey presto a flag using a fishing rod from the shed.
K.I.T
Knight rider
d(^_^)b
Vehicle: 91 sierra
Post Posted: Mon Jan 03, 2011 3:53 am
where can i find information about these led's as i have been trying many ideas to get a led on top of my flag but I'm failing, i have lost about 6 led lights not as they have come off and broken
Users browsing this forum: No registered users and 11 guests
