It is currently Thu Nov 05, 2026 11:30 am
Vehicle: 75 Cruiser
Post Posted: Fri Feb 25, 2011 9:55 am
Here's a basic chain axle puller.
Stick your hub on backwards, grab a bit of chain and run in around the hub, grab a big hammer or big bit steel and do a bit of a whack motion outwards.
The photos probably explain it better.
Post Posted: Fri Feb 25, 2011 10:00 am
Gotta love backyard tech :)
My way of doing it for the Vit...
1) Take the wheel off and undo whatever you need to (drum brake/axle bolts etc).
2) Put wheel back on and do the wheel nuts up just a few threads each
3) Get yourself in position, and yank the wheel as hard as you can :)
Only has above 10 - 15mm of movement before it hits the wheelnuts, but with the weight of the wheel behind it she usually comes off with just one or two pulls.
Moses' SQ625 GV Pig
Vehicle: Sj70 tintop
Post Posted: Fri Feb 25, 2011 10:01 am
do you and shep share the same double helix? he will love this, than copy the idea, but the chain will become telecom rope and the hammer will be a lump of metal he found at the dump.
looks pretty good, cheaper than a proper puller.
Sj70 tintop
Post Posted: Fri Feb 25, 2011 1:45 pm
i usually just chuck on of the spare 10 rims i have here on and bash it with a rubber mallet. always worked for me.
This idea i will keep in mind though times the above method does not work
Post Posted: Fri Feb 25, 2011 6:11 pm
X2 since you showed me that i have never tried anything else...... works great :D
Post Posted: Fri Mar 04, 2011 7:49 am
I use an old brake rotor turned backwards, three studs and lugs a couple of threads and use the rotor as a slide hammer.
All of above sound good too.
Post Posted: Tue Dec 27, 2011 12:39 pm
I found the easy way in a Sierra is to undo all the bolts and use the backing plate a slide hammer if that makes sence one good pull and shell pop out pretty easy just make sure you don't hit any important bits hahahha
Users browsing this forum: No registered users and 16 guests
