It is currently Mon Oct 19, 2026 9:17 pm
Vehicle: 85 hightop drover
Post Posted: Thu Oct 20, 2011 12:16 am
Am looking at getting some tyre deflaters, looking on ebay
there are cheap ones and expensive ones. is there any difference?
in quality? and performance? what ones should i get?
16valve efi hightop drover
Post Posted: Thu Oct 20, 2011 12:24 am
Got myself one a E-Z Tyre Deflator from ARB
http://www.arb.com.au/products/general- ... cessories/
or if you want the same guage but cheaper....
Speedy Tyre Deflator and Guage
http://www.ironmandealer.com.au/tyredeflator.htm
http://www.prestigeoffroad.com.au/compr ... -and-guage
Vehicle: Yellow Ute
Post Posted: Thu Oct 20, 2011 12:32 am
What do you think of the arb one?
Post Posted: Thu Oct 20, 2011 12:38 am
I wouldn't get the staun knock-offs if they are the ones you are talking about. The knock-offs make a shocking hissing noise as they let the air out, and are a good deal slower also than the stauns.
Most of the guys I head out with either have the arb ezy deflator or stauns. Both have their good/bad points. If you only ever drop to one pressure I'd go the stauns personally. If you like to use different pressures all the time go the ezy deflator.
Moses' SQ625 GV Pig
Vehicle: WT Tinny, NT lwb, 1L lwb
Post Posted: Thu Oct 20, 2011 12:40 am
I've got the arb ezy deflator and it's pretty good, can't fault the quality or ease of use.
JrZook - Mine only hangs 2.5".
 Profile WWW ICQ YIM
Post Posted: Thu Oct 20, 2011 12:46 am
Yeah the ones I want are 4x screw in
Type, not the gauge type
Post Posted: Thu Oct 20, 2011 12:53 am
Staun would be your go then.
I'm not a fan of the EZY deflator.. it shows the wrong reading nowadays.
(Few months old and has had HEAPS of use)
Post Posted: Thu Oct 20, 2011 1:32 am
Love it....best money i spent apart from the ARB air compressor
It takes me maybe 5 minutes to deflate my tires (takes out the valve and lets air out much quicker)
I didn't want to spend that much money on a tyre deflater but it makes life so much easier and you can vary the pressures which is great if the rear of the car is fully loaded and you want to keep a few more PSI in the rear tyres.
I was going to buy the staun deflaters but once you set the pressures you can't really change them and they're nearly as much as the deflator
My theory is....buy once.....
Post Posted: Thu Oct 20, 2011 1:36 am
IMO....spend the extra $40-50 and get a proper guage ;)
My mate had the Staun deflaters and had them set by a 4WD shop. After a few trips they just weren't setting to the same/right pressures they were originally set to....took them back twice to re-set them and then finally sold them after he saw my guage
Vehicle: 02 jimny
Post Posted: Thu Oct 20, 2011 3:17 am
Imo ez arb ones are the way to go
LIVING LIFE ON THE EDGE, TILL YA ROLL
Vehicle: 02 jimny
Post Posted: Thu Oct 20, 2011 4:24 am
Post Posted: Thu Oct 20, 2011 4:26 am
ARB one is awesome.
Better than stock...but not by much.
 Profile YIM
Post Posted: Thu Oct 20, 2011 5:11 am
I have a set of staun deflators here if you want them. $25 and i'll post them to ya. I got them about 6 years ago and used them maybe twice and they have been sitting in a drawer for the last 5 years and 11 months :D Shoot me a pm if your interested. (I don't know what they are set for or how to set them, and they don't have the case thing they came with when I got them :p)
Post Posted: Thu Oct 20, 2011 5:49 am
Thanks bohuler, but a mate just said
That same thing, and I'll take his
For test run, try them out, he also has
The ARB one I'll try that also, thanks
Vehicle: LWB Sierra & XL7
Post Posted: Thu Oct 20, 2011 5:54 am
I prefer Stauns. Screw them on and go have a chat to those using the EZ Deflator.
Over the weekend someone was using the EZ deflator and checked the pressure with one of those new properly calibrated big dial low pressure tyre guage from ARB and found that the EZ deflator were about 2 psi out.
Hahaha, the instructions on how to set them on the package. :crazy:
It's as simple as, lowering a tyre down to desired pressure, unlock the locking ring, screw the main part until it starts to let air out, push the button at the end and tighten the locking ring.
To service, simply unscrew the whole lot, lubricate the insides with WD40, lanoline, silicon or similar, see process above.
Post Posted: Thu Oct 20, 2011 6:07 am
Main thing with the stauns is keep them clean. If they get dusty or if you drop them in the sand they'll start sticking and your pressures will be all over the place. If you do just strip and lubricate them as mentioned above.
Keep them clean and they are usually pretty bloody accurate, I've found mine are always within 1psi.
Moses' SQ625 GV Pig
Post Posted: Thu Oct 20, 2011 6:24 am
I agree with you buzbox the screw in look so easy
When I've see them used. I seen my mates use the
ARB EZ Deflator and it look clumsy and time-consuming
To use (but he does drive a "cheap" no sorry a jeep)
Post Posted: Thu Oct 20, 2011 7:27 am
The EZ deflator is good apart from the longevity of its accuracy.
All the guys i know that have them loved them at the beginning now we all hate them cos they are like 10psi out, even took it to ARB and they said they had no idea.
Post Posted: Thu Oct 20, 2011 8:24 am
I have both, the stauns still work good (5 years), And let you walk around and talk crap while they are delfating. only problem being the 1 pressure you set them to. 2 sets would be good, one for beach, 1 for mud/rocks.
The arb thing i have still works and is good for using different pressures, but mine is 6psi out, and this is the same for most of my mates.
Post Posted: Thu Oct 20, 2011 8:27 am
no need for 2 sets.
I use 2 deflators set at 17psi and the other 2 are set at 14-15. I've marked them with a texta to tell which ones which.
Users browsing this forum: No registered users and 435 guests
