It is currently Sun Nov 15, 2026 6:13 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page 1, 2, 3  Next
Post Posted: Tue Aug 19, 2008 2:36 am
ahhh....finnaly pulled the finger out after a few years of testing...with great results.features:
larger bearing design
all steel
can be used to press off old bearings onced installed
no proportioning valve needed.
available now......
Vehicle: 75 Cruiser
Post Posted: Tue Aug 19, 2008 10:25 am
Looks good.
I can't use any, but you know everyone will ask the question...
How much you selling for?
Post Posted: Tue Aug 19, 2008 12:23 pm
'Caliper' is spelt with one 'L' :P
Where does the caliper sit? As i've seen disk brake conversions with chassis clearance problems. It looks like you can position the caliper in front or behind the axle housing?
Post Posted: Tue Aug 19, 2008 10:41 pm
here's how they mount. p.m ya soon damo.
Post Posted: Wed Aug 20, 2008 1:14 am
any info on price?
Be keen on these depending on price.
Post Posted: Wed Aug 20, 2008 1:37 am
what diff are they to suit............. im guessing sierra
Post Posted: Wed Aug 20, 2008 2:23 am
they will be approx $380 a pair and will suit sierra's without hand brake drum. vitara's to come shortly after. handbrake sierra will be catered for with a different caliper later.
Post Posted: Wed Aug 20, 2008 2:58 am
Why are they two piece? is it for the bearing fitment
Post Posted: Wed Aug 20, 2008 3:11 am
mainly so i can cater for some of my custom housing setups ( different caliper offsets).
Post Posted: Fri Aug 22, 2008 1:43 am
a bit pricey compared to the ones from the states but still not too bad. let us know when ya have some in stock. cheers
Post Posted: Fri Aug 22, 2008 4:25 pm
Looks nice.
sometimes having the slot can be good also not taking the brakes off when changing wh bearings or broken axle.
so guessing also the pintara caliper is using less force then the sierra calipers so not lockups? is this also using the zook front discs?
If in Doubt Power out.
1.6 big block and twin loc
Post Posted: Sun Sep 07, 2008 4:51 am
Mines narrow track 1.0 litre, when caliper sat upright, it hit my chassis.
This may not be an issue with Wide track, and/or less travel suspensions. My bolts are 45* out from wt, also.
Problem was solved by rotating them forarward one bolt. Just a pain when bleeding, as nipple needs to be vertical. I undo caliper and slide it up top for bleeding, then slide back and rebolt.
NB mines a home made kit by a different Joey mate.
It looks to me like you could vary caliper positions.
christover
Post Posted: Sun Sep 07, 2008 1:57 pm
the caliper sits facing rearward and bleeding is not a problem as the nipple is in the correct position. oh, and changing wheel bearings is not much of an issue remembering it uses LARGER bearings so they don't need to be replaced as often.
Post Posted: Sun Sep 07, 2008 3:03 pm
The only prob I can see if I want to carry spare rear shafts :cry:
Post Posted: Tue Sep 09, 2008 7:35 pm
how she faces, don't worry, they can be made so the axles are a quick swap.
Post Posted: Tue Sep 09, 2008 7:48 pm
That'd be just a slot in the bracket yeah?
joeblow wrote:
The flexible brake line, is that a stock Sierra front?
Handbrake cable is from the caliper donor vehicle?
What's the swaybar off?
Post Posted: Tue Sep 09, 2008 8:08 pm
the axle can slide out once the bolts are un-done. the brake like is the one for the caliper, as is the hand brake cable. the swaybar is factory early 1.0 litre lwb, very rare. can get ya some pics of the sway bar if ya want.
Post Posted: Tue Sep 09, 2008 8:32 pm
Just send me the swaybar :P
I've got a Vit one I was going to try to adapt to it but I was afraid it was going to be a little too stiff.
Post Posted: Fri Nov 07, 2008 1:14 am
How is the progress going on these Joe
Zook ute, 4.6's, 1.6EFI, Auto, S3 R/H, SPOA, 34"JT
Post Posted: Mon Nov 17, 2008 9:11 pm
these still being made/ designed sold? look like a pretty good setup.. esp the bigger bearing idea..
would be very keen on getting a set.
Post Posted: Thu Nov 20, 2008 1:08 am
yep good to go. if anyone is interested please pm me as i will start a batch around christams.
Post Posted: Thu Nov 20, 2008 5:33 am
if you do up some sierra caliper mounts for the rear i am keen.. just so i can look at doing the same pads all round.. easier for me.. will put in a prop valve. ill shut up if too off topic ;) :D
if not ill aim at pintara calipers fo sure.
Vehicle: WR250F/Jeep XJ
Post Posted: Wed Dec 31, 2008 9:11 pm
Joe how would the proportioning go if I were to fit GV Front discs and calipers?
Are you using sierra front rotors with these calipers?
What are you suggesting people do for wheel hubs? Would you include in your $380 price machining/cutting down of buyer supplied standard rear drums for use as axle/rotor hubs?
Joe I reckon you could sell these (i would buy them) if you could supply the hubs/hub machining as well.
A snake racing kit is $480 with Hubs.
A spidertrax kit is around $380AU shipped with hubs.
Noteably both these kits use sierra calipers and rotors and don't account for handbrake application though.
Anyway just a few thoughts etc for you to ponder! :D
Post Posted: Fri Jan 02, 2009 3:41 am
Joe do you make these for WT (with handbrake in drum) yet?
I am keen on converting to disc ASAP. Sick of replacing drum brake shoes every 3 or 4 weeks! :roll: Mud sux. :evil:
Jas.
Post Posted: Fri Jan 02, 2009 1:23 pm
Jas.
AFAIK Joe uses an R31 caliper with these which has a built in hand brake.
Post Posted: Fri Jan 02, 2009 11:25 pm
Jas.
I have a pair of pintara rear calipers and discs. (Calipers are same as magna rears)
So when do you start production of these babies to suit 89 onwards WT Zooks?
Post Posted: Mon Jan 05, 2009 2:51 pm
very keen on a set of these as soon as you've got them built Joe..
cheers,
Dave.
Post Posted: Mon Jan 05, 2009 8:44 pm
O.K people. I have been busy finishing drawings, instructions etc for these mounts and they are just about ready to go. Everything has been on hold for a while as i waited for steel prices to settle down and stop fluctuating so much, which they seem to have done (for now!). I have also slightly re-disigned them to eliminate the machining process, so please check out the jpeg at the bottom. Here are a list of features etc that will hopefully answer most ask questions.
- They will suit all Sierra's with handbrake in the rear drums.
- They are designed to make use of the larger RW507 wheel bearing available from all bearing outlets. Please note with these bearings you must still use the Sierra retaing collar and seal.
- Laser cut adaptor will be an option but is still being designed. You can either get someone to machine down your drums or use the adaptors. They will not come with the kit and must be ordered seperately.
- The hanbrake mechanism is for the owner to work out, but i will supply some pictures of how i have done mine. I used the Nissan cable and adapted it to my Sierra with a few brackets. I will be looking at making adaptors for the Nissan cable but bear with me. If i do these will also be a seperate item.
- There must use a rubber brake line from caliper to diff. The reason i say this is i have seen many people take a shortcut and hook up a steel pipe directly to the caliper...THIS WILL NOT WORK AND IS UNSAFE. It will take someone with a flaring tool 5 minutes to do it properly.
- Depending on your vehicle wight a proportioning valve will not be required. The reason i say this is to warn anyone with a cut off arse end that has less than factory wieght- it may over-brake on the bum. To those with normal and or heavier arse end you will be fine.
- I'm hoping to now get the mounts under the 300 buck a vehicle mark, but i will know more in a week or so.
- They will be zinc plated and come with fastening hardware.
I have also done non rear handbrake mounts using toyota stuff for people with t/case brakes. If anyone is keen on these let me know.
Post Posted: Mon Jan 05, 2009 10:29 pm
Good stuff Joe...
I'm keen to get a set ASAP.
Jas.
Post Posted: Tue Jan 06, 2009 2:38 am
I still want some. Ive got everything but the calipers.
