It is currently Mon Oct 19, 2026 11:38 pm
Post Posted: Sat Nov 28, 2009 10:59 pm
I couldn't figure out how to do this but it's all a bit simple once you have done it :D It's a big radiator so an extra 60mm wider and 530mm tall. To make it fit i had to remove the plastic guard, a mate went over the pit's and was told that he needed to replace it or find something else to hold up the brake lines. I use a piece of 25 EA and drilled two holes 545mm apart and fitted it.
Then i cut the passengers side (PS) bracket off level and used a piece of 65mm EA, the difference was 60mm so that's the length i cut the angle. Once all is cut up it's joined together like so.
I used standard vit rad supports but cut down to fit between the chassis rails, on the drivers side (DS) i had to join on a piece of 10x3x20 flat bar, this was because the vit rad supports sat snug around the steering box and the DS sierra bracket didn't line up so i had to join a piece to drill holes into.
well that's pretty much it, it was simple and took a day out in the shed. Ill be pulling it all back out due to the missing engine and split washers then painting it black so it all blends in. The top of the vit rad sits nearly identical to the height of the sierra so can't really ask for much more than that :D
Post Posted: Sat Nov 28, 2009 11:05 pm
Looking good
Post Posted: Sun Nov 29, 2009 12:01 am
"Lemme ask you a question Ted, do you see anything wrong here?"
"No"
"We aint got no engines do we! Do we! Do we!"
Good work btw
Post Posted: Sun Nov 29, 2009 12:42 am
whats wrong with a 1.3 radiator?
remeber that day at stockton? my temps where acelly cooler on the sand then on the highway coming there.
got to about 90c on the highway. and i was flogging it hard that day
navara on 33s. hopfully rear air locker soon
Post Posted: Sun Nov 29, 2009 12:45 am
thanks scrawn and PJ :D
the 1.3 rad was rusty and NIK had the rad siting at his house gotta love free mods :lol:
Post Posted: Tue Dec 01, 2009 11:59 pm
good job man.Nothing wrong with having a bigger rad sitting under there.im kicking myself now for not going a vit one when i put in my power steer seeing as tho i had to hack the rad mounts up anyway.
Report back once shes all running wont ya
Post Posted: Wed Dec 02, 2009 12:24 am
Nice job, get yourself a vit fan and shroud when you stick your engine back in :)
Post Posted: Sat Dec 05, 2009 2:31 am
hmm i have a vit shroud and a sierra fan will that do? i think that the vit shroud might not be correctly located for a sierra engine.... but never the less ill see what i can come up with... i need to weld on a over flow bottle mount also.
Post Posted: Sat Dec 05, 2009 5:17 am
yeh i drilled mine out and then welded it to my new 25x25 angle upright.But i test fitted the bottle a little too soon after welding and melted a tiny pin hole in it :oops: :D
Post Posted: Sat Dec 05, 2009 4:44 pm
haha i had not thought of that yet...thanks :lol:
Post Posted: Sun Dec 06, 2009 3:08 am
no you need a vit fan too, the hole is too big
it all lines up trust me, been there done that :)
Post Posted: Sun Dec 06, 2009 2:48 pm
haha ok ill get it all sorted when i get the motor in :D
Post Posted: Mon Dec 07, 2009 6:20 pm
I just rang a radiator place advertising vitara radiators for 185, but they say that the sizes are vastly different to what you say, 700mm tall, they have no listing for this.
Do you perchance know of the vehicle model/year its from.
The vitara is 425mm by 490mm Thats the biggest in the book.
Post Posted: Wed Dec 09, 2009 10:53 pm
hmm sorry wrote the wrong thing i thought that the bigger one is 700 but im not sure where i got that idea from... from rad cap, too-bottom of the auto box cooler tube thingo, is 530mm. no word of a lie. that 40mm bigger then what you say??? i have no idea what model it's off, but i can show you the ground i found it on...lol
Post Posted: Wed Dec 09, 2009 10:57 pm
Taa mate, thats more like it.
Radiators are measured only on the core, so 530 is cool, a core of 700 would be one hell of a core to get onto the zook hey hehe.
Post Posted: Thu Dec 10, 2009 9:52 pm
haha yea it would be usless pretty much, royce does a vit fan bolt straight on?
Users browsing this forum: No registered users and 42 guests
