It is currently Mon Oct 19, 2026 11:39 pm
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Apr 16, 2010 10:19 pm
Just looking to remove some bits and pieces to tidy up the ride
- metal corner mounts from front and rear bumpers
- wheel jack mount from engine bay
Going this route as it's proving to be spots where surface rust is trying to get to the next level of panel destruction :evil:
Should I just angle grind these bits off or is there an easier way - i'm guessing there's just one or two pinch welds holding these bits on.
Also looking to weld the cracks that have started on my window sil (the outside door skin is flapping like crazy)
Not a fabrication expert, but i've done a basic engineering (metalwork) course 10 yeasrs ago, but I ain't touched a mig / tig /arc since, and it's all but forgotten.
Vehicle: jimny
Post Posted: Fri Apr 16, 2010 11:36 pm
get some spot weld drills and drill out the spot welds
Post Posted: Sat Apr 17, 2010 3:59 am
Low angle drill bits... can't remember seeing them at Bunnings any time recently - where to find them?
Vehicle: jimny
Post Posted: Sat Apr 17, 2010 8:55 am
I sell them but they are well above most peoples budget. Try super cheap
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Tue Apr 20, 2010 4:42 pm
Bunnings have those Ozito Dremmel knockoffs cheap, you can then get dremmel bits. I have the DSE version with dremmel bits & cutting discs.
you can cut off the sheet around the welds then grind them flush this way.
Then you have a dremmel which is probably more flexible than the drill bits at about the same price.. I use mine all the time.
Users browsing this forum: No registered users and 39 guests
