[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Fri Oct 17, 2008 10:04 pm |
yer yer i'm sure everyone will think it's dodgy.. but it's for offroad use only.... and it works.
I needed a 100mm longer shaft, so i cut two shafts and sleeved it with some tube. I drilled some holes along the standard shaft and once the tube was inside i welded in the holes, basicly connecting the outside tube to the inside tube.
This is about 100mm longer than standard.
JrZook
 Posted: Fri Oct 17, 2008 10:44 pm |
For a gain of |<-------------------------->| much may i ask why a drive shaft spacer didnt do the trick? Or does it already have one?
Ps welds look ok
Dan
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Fri Oct 17, 2008 10:50 pm |
yeah how long is the extension? it looks less then 1 inch
steve
Vehicle: 75 Cruiser
 Posted: Fri Oct 17, 2008 10:53 pm |
now i remember. It's actually two different shafts. i purprosly cut them both that length , so i had a space to weld them to the inner tube.
PS. where the cut on the long side of the shaft is, is where the shaft ended.
It's a front shaft with a rear shaft end welded on,.. I'll get a measurement tomorrow for the hell of it.
basketcase
 Posted: Sat Oct 18, 2008 3:13 am |
That seems fine. Its a trail rig, why would you bother buying a spacer?? Doesn't need to be perfectly balanced or anything. I would even go as far as RHS shafts on a trail rig. When your going slow they don't need to be balanced.
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Sat Oct 18, 2008 12:01 pm |
A mate of mine uses a RHS shaft in the front of hil hilux. works well but it does seem to flog out the uni's alot quicker
royce
 Posted: Mon Oct 20, 2008 2:40 pm |
another trick is to get some heavywall pipe the right diameter and replace the whole lot, then its more impact resistent too
[ 7 posts ] |
Users browsing this forum: No registered users and 25 guests
