It is currently Mon Oct 19, 2026 11:37 pm
Vehicle: Coil Sierra
Post Posted: Mon May 11, 2015 10:10 pm
I've been working on an adapter to fit a M13A Jimny power steering pump to a G13BA block.
Since the G13BB and Vitara pump are a direct fit, the M13A pump required some modification to fit the G13BA block.
If there is any interest, after the bracket is finished I can have a run of these laser cut.
There is a few modifications to the original M13A bracket due to the shape and size, as well as designing the mount so the pump can tilt and work as a tensioner for the belt.
Post Posted: Mon May 11, 2015 11:32 pm
Must of miss your want add i would swap m13a bracket for your g13bb one if you still interested in one i am in Strathpine
Post Posted: Wed May 13, 2015 7:55 pm
Hey, ive only got a M13A bracket. Never had a G13BB hence why ive made a bracket to use the M13A on a G series motor.
Post Posted: Sat May 16, 2015 11:44 pm
The pump is on, just need to sort out the top bracket so it tensions the belt.
Users browsing this forum: No registered users and 41 guests
