It is currently Mon Oct 19, 2026 10:36 pm
Vehicle: 2012 Facelift Jimny JX
Post Posted: Mon Aug 31, 2015 12:25 pm
Hi,
I live in New Zealand and I'm interested to know what other like minded Jimny owners have come up with for front recovery points. I know this is a constant source of discussion, but here's my experience so far:
I have an after market front hook fitted to my facelift Jimny. The Japanese sourced Apio hook (6mm) has not been able to handle the punishment I've thrown at it over the last 3 years. It had started to deform quite badly, so I took it off for a closer look and unfortunately found a small crack in the factory recovery point where it is welded to the underside of the chassis.
Once I get this repaired, I'm going to make a heavier bracket, 8mm, which will use the same concept. But I'm going to make the shackle connection point closer to the chassis and also pick up on the steering mounts (longer bolts required).
I would also extend the connection at the cross member (rear) to also clamp around the chassis. I'm also thinking a couple of 8mm gussets stitch welded in place will limit side deflection. I'm not 100% on the idea of utilising the steering box bolts, although the chassis is fitted with crush tubes so should be reasonable strong...
I've included photos showing the crack, Apio hook and my proposed fix. (not sure I've got sharing of photos sorted though...hmm)
I'm interested to know peoples what opinions are?
[img]http://s1370.photobucket.com/user/obansam/media/Crack_zpswtmyqifv.jpg.html?filters[user]=141614094&filters[recent]=1&sort=1&o=4[/img]
[img]http://s1370.photobucket.com/user/obansam/media/WP_20150829_17_11_18_Pro_zps4emqhjpt.jpg.html?filters[user]=141614094&filters[recent]=1&sort=1&o=0[/img]
[img]http://s1370.photobucket.com/user/obansam/media/WP_20150829_17_14_52_Pro_zpsperxwlym.jpg.html?filters[user]=141614094&filters[recent]=1&sort=1&o=1[/img]
[img]http://s1370.photobucket.com/user/obansam/media/Option1_A_zpsazrlaisz.jpg.html?filters[user]=141614094&filters[recent]=1&sort=1&o=5[/img]
Post Posted: Mon Aug 31, 2015 4:07 pm
In your Photobucket, right click over an image and "Copy Image URL". Then paste that URL between the img tags.
Here you go
I'm not familiar with the Jimny chassis but I suspect you are on the right track.
Cheers!
Chris
Vehicle: Suzuki Jimny 2009
Post Posted: Sat Sep 05, 2015 6:42 pm
I think it shows that the APIO hook is not meant to have lateral forces on it. Your proposed solution looks good to me.
Mike
Vehicle: Suzuki Jimny 2013
Post Posted: Sun Sep 06, 2015 8:17 pm
I have the APIO front hook, but it is the 9mm version instead of the 6mm. Haven't had to use it yet but it seems looks pretty strong?
Users browsing this forum: No registered users and 24 guests
