It is currently Tue Oct 27, 2026 7:18 am
Post new topic Reply to topic  [ 542 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 19  Next
Post Posted: Thu Jul 29, 2010 9:25 am
got_bar_work wrote:
Hey Joe will gv hubs fit on this and can u make it as wide as a gv diff to go in 1.6vit
why are you after a diff that is gv width?
projects are comming along. just sorting out the 'larger' cv's and axles. kenny was up to see progress and left with a smile on his face. :wink:
hoping to have the whole cv and axle system at around the 400 buck mark........NO MATTER WHAT TYPE OF ZOOK YOU HAVE. 8)
Post Posted: Fri Jul 30, 2010 10:17 am
was thinking that i could throw a gv diff in the back to widen up the track
wat cv u using now
Post Posted: Fri Jul 30, 2010 10:36 am
wat cv u using now
there will be the option of running standard zook stuff, plus i will be making custom axles with a larger 'off the shelf' cv with which i can make all sorts of custom widths. as progress continues i will post pics of this cv set up.
i'm also looking at making a knuckle felt eliminator kit. :wink:
Post Posted: Fri Jul 30, 2010 6:45 pm
pajero rear control arms are the right shape at the diff end u want ,but they are a pin at the chassis not a bush
Post Posted: Tue Aug 03, 2010 11:03 am
thanks for that GBW.
some more pics. been crook this weekend so not a heap got done.
the v6 'jig' waiting to come in....
the new diff under the yellow thing to check for alignment.
Post Posted: Wed Aug 04, 2010 12:01 am
I know you would already have thought of this, but just in case.
Will the panhard rod clash witht the left control arm mount or diff pumpkin on full compression.
I'm not as familiar with the landscape under the front of these, but it just doesn't seem to have enough clearance as most Panhards are mounted so that they are basically horizontal at standard ride height.
I'm probably wrong. :oops:
Post Posted: Thu Aug 05, 2010 9:06 am
don't know if you have answered this and i missed it but how many mm will you get when flexed up with those arms from chassis to diff housing? what will the ride height be sitting at as well?
Post Posted: Thu Aug 12, 2010 9:11 am
the panhard will work out. it will be the last thing to go in.
Post Posted: Thu Aug 12, 2010 9:12 am
central bumpstops will be re-worked to suit. the ride height will be as it was with the a-frame.
here is a pic of the trial cv..............just fits!
Post Posted: Thu Aug 12, 2010 9:14 am
F*&K me thats tight!!
Post Posted: Thu Aug 12, 2010 9:19 am
if i was female i'd be blushing........ :oops:
externally a little bigger than a sierra.........internally (cage and balls) bugger me!
Post Posted: Thu Aug 12, 2010 9:21 am
So I assume it doesn't bind inside the knuckle?
Post Posted: Thu Aug 12, 2010 9:25 am
now that would be silly if i didn't check eh?....... :wink:
some more trickery will be added to the front to compensate for the trickery i'm doing to the rear.......will keep pics comming. (will apply to vits also)
the only thing left untouched so far are those silly small king pin bearings......i'm sure i'll figure something out..... :?
Post Posted: Thu Aug 12, 2010 9:31 am
Then I will assume that you have allowed for the 'expansion' of the cv joint when at full lock? Even though its not much, it doesn't look like you have much room to play with there :D
Post Posted: Thu Aug 12, 2010 10:01 am
IFS Hilux?
Post Posted: Mon Aug 16, 2010 8:19 am
Not sure if you are still looking for orders, but if you are I'll put my name down for one to suit a SV Vit. :)
Possibly a dumb question, but with the new CVs/axles you are talking about would we retain the standard vitara diff carrier/gears (ie. would I still be able to use my 5.12s and lockright locker). Sorry if its already been listed, had a flick through the thread but couldnt see it.
Moses' SQ625 GV Pig
Post Posted: Mon Aug 16, 2010 9:14 am
hilux?...................no......but will be one of the ones i also look into.
yes, still looking for orders. these axles will be made to suit 26 spline fronts so no dramas there. the first trial axles will be made this week. these cv's will come with a 10mm machined spacer for each side of the vehicle (between knuckle and spindle). it will give me clearance for steering arms as well as giving some more clearance for those larger tyres on a leafy sierra :wink: without having to use wheel spacers.
and don't stress vit owners.......the first vit diff is oh so close.(i need one for mine too). plus.....no sooner do i clear some cars......more turn up.
kenns lj for fabbed wt diffs with larger axles and coils and a full floater system for the rear with discs. (still twisting my arm for dualies in an lj......)
and tabs swb to finish off because he is a freakin lazy pr#@k!
Post Posted: Mon Aug 16, 2010 10:59 am
will you be making these axles in 1 off batch, or will they be ongoingly available? eventually i'd like one under my swb vitara, but ive plenty of stuff to get done beforehand :wink:
Go Hard, Trailer Home
Post Posted: Mon Aug 16, 2010 11:07 am
Excellent! Sounding better and better.
Moses' SQ625 GV Pig
Vehicle: SJ50 hardtop!
Post Posted: Mon Aug 16, 2010 11:43 am
Probably been answered before but search doesn't work on my phone.
What size tyres will this SAS kit for the vit be safely capable of running? I know its aimed to be more legal then "go big", but yeah...rough idea??
NT SJ50
Post Posted: Mon Aug 16, 2010 9:43 pm
If I know Joe it will be upto 33's but dont quote me...
Post Posted: Mon Aug 16, 2010 9:47 pm
Joe the second transfer will fit and i'l work out the shift sticks ... :please:
Post Posted: Wed Aug 18, 2010 9:57 am
if you have some gearing 33's will be fine.
i have finished the 'roughing' of the axle, just awaiting cutting the splines on the weekend. i'm also investing heavily on tooling for this project so it IS going ahead. i just want things right before going into production.
some pics so far.
Post Posted: Wed Aug 18, 2010 7:37 pm
So when can we get them with portals so we can have the gearing changed to suit 33
Vehicle: 2003 grand vitara
Post Posted: Thu Aug 19, 2010 11:11 am
i too will be keen for a vit lwb
Post Posted: Sun Aug 22, 2010 9:47 am
mmmmm.....maybe......
first axle roughed and splined.......all is good :wink:
Post Posted: Sun Aug 22, 2010 9:53 am
you not going to make rear axel shafts at all are you for the sv vitara's
stay tuned.......... :wink:
Post Posted: Sun Aug 22, 2010 9:54 am
i likies
Post Posted: Sun Aug 22, 2010 9:58 am
if you are making cv's from scratch are you going to be building upgraded cv's for sierra's? or isn't there enough market because of chromo's?
Users browsing this forum: No registered users and 7 guests
