It is currently Sun Nov 15, 2026 7:00 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
Vehicle: Nissan
Post Posted: Fri Apr 16, 2010 11:53 pm
dad and I made some more mounts, installed reverse lights and inserted tube in rear section of chasie
Pearce-toff Racing
Vehicle: Nissan
Post Posted: Fri Apr 16, 2010 11:54 pm
finnish product 8)
Pearce-toff Racing
Post Posted: Sat Apr 17, 2010 2:56 am
Well done. Looks great a very neat job I reckon u must be happy with it.
Thanks for posting pic's
98 GV
Vehicle: Nissan
Post Posted: Sat Apr 17, 2010 3:11 am
thanks yer verry happy with it :D
Pearce-toff Racing
Post Posted: Sat Apr 17, 2010 11:37 am
Now go bend it, I mean test it. :oops: :roll: :P
Post Posted: Sat Apr 17, 2010 12:24 pm
Cutting into the bodywork 8O ..... Beginning of the end for this old girl :wink:
Bring on the LWB
Vehicle: Nissan
Post Posted: Sun Apr 18, 2010 1:07 am
Bring on the LWB
we are making some bucket things for em :wink:
Pearce-toff Racing
Post Posted: Sun Apr 18, 2010 12:34 pm
looks ok seen it yesterday at tha comp, wats with ya rear springs how they are lower, that box that is welded in there????????
2''lift 31's twin locked & 6.5s
Post Posted: Tue Apr 20, 2010 10:37 pm
Nice bar, looks good mate.
Post Posted: Tue Apr 20, 2010 10:56 pm
you wanna make another one ill buy one
Vehicle: Nissan
Post Posted: Tue Apr 20, 2010 11:04 pm
for the same thing with LED tail lights proberly cost about $600 for the amout of work involved :wink:
Pearce-toff Racing
Post Posted: Tue Apr 20, 2010 11:50 pm
wat bout just that bar no toe bar point no light just the bar
Post Posted: Wed Apr 21, 2010 9:57 am
Image[/quote]
Ok ok here i am :lol:[/quote]
ill give you a tip from a sheety whose had a bit of practice of sanding off welds on s/s handrails. when sanding welds off on mandrel bends turn your grinder the other way youll get it heaps neater and less flat spots. awesome job though i likes it very much. different from all the rear bars i have seen.
Post Posted: Thu Apr 22, 2010 8:27 pm
Good job on the bar. What are the lifting eyelets rated at? They really should be over 5t if you plan to use them as recovery points.
Pete
Post Posted: Thu Apr 22, 2010 9:19 pm
It allows him to run standard height shackles but gives him the effects
of using extended shackles. Does that make sense? :?
Post Posted: Fri Apr 23, 2010 12:17 am
No, it doesn't.. All it does is lift the car. The only thing that gives the benefits of longer shackles IS LONGER SHACKLES.
Post Posted: Fri Apr 23, 2010 12:30 am
my bad... I just thought that instead of lifting the car
Using longer shackles, he can pack up the standard mount.
Post Posted: Fri Apr 23, 2010 5:01 am
Having that block there will change the shackle angle, potentially giving the shackle a larger range of motion when the spring flexes downwards, providing that the springs and shocks allow it...
I want my old sig back :(
Post Posted: Fri Apr 23, 2010 1:33 pm
Sorry to drag your thread off topic Alex.
Ben: Putting that spacer in has only lowered the spring/raised the car as it is still in the original position.
IF it were moved forward your theory would be correct, it would induce more static shackle angle and more droop... But it's not forward.
Vehicle: Nissan
Post Posted: Fri Apr 23, 2010 9:39 pm
hehehe its cool. took a couple of goes to move it in the right spot coz it has to go back as it goes down :D
Pearce-toff Racing
Users browsing this forum: No registered users and 13 guests
