It is currently Mon Sep 21, 2026 6:35 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
Post Posted: Tue Dec 14, 2010 7:40 am
OK well I got into this Saturday. The gutter straitening part is dead simple; however the dint in the side of the car is not... The most effective method I found to get it to where it is, was to clamp the vice grips onto the gutter, and hang off the car slowly pulling the body out. However its still not straight enough :(
You can see it clearly in both the "after" pictures. Any one got any suggestions on getting it out further? (remembering its a double panel behind where the dint is).
Clearance Hole Technology :P
Post Posted: Tue Dec 14, 2010 8:41 am
Maybe you could make a clamp about 100mm long that bolts together and encompasses the gutter to which you could attach a slide hammer and pull it out? Or make it a soft top...did I just type that aloud?
Post Posted: Tue Dec 14, 2010 8:55 am
That might work :)
Typed what aloud? :?
Post Posted: Tue Dec 14, 2010 8:56 am
Highway-Star wrote:
That might work :)
It's clearer than Buttercup being a waste of time, you need to chop it!!!!
:roll:
Post Posted: Tue Dec 14, 2010 9:23 am
X2 slide hammer is what is needed
Vehicle: LPG 1.6 Sierra
Post Posted: Tue Dec 14, 2010 9:41 am
lordfury007 wrote:
pics or it didn't happen :P
Totally forgot about this post. I'll take a pic now and show an A/B if the flash works out
Edit - too dark, not enough background light for the flash
Post Posted: Tue Dec 14, 2010 11:04 am
OK Slide hammer it is then. Will take the window back out first.... just in case... :oops:
I think I'm going to have to organise a tintop only run sometime...and all you angle grinder happy soft top drivers can bite me! :thefinger:
Post Posted: Tue Dec 14, 2010 10:20 pm
che_guitarra wrote:
Fixed enough for me
Post Posted: Tue Dec 14, 2010 10:36 pm
that's a top effort, what did you use?
Post Posted: Tue Dec 14, 2010 10:49 pm
2x hardened metal bars 1cm x 1cm x 20cm long to fit in the gutter, a pair of vice grips, and a hammer for the stubborn bits
Post Posted: Tue Dec 14, 2010 10:57 pm
guters look great, i will be using the same sort of thing for mine when i do them.
Highway stars are a bit more of a problem as they involve the roof section being dented aswell.
Post Posted: Wed Dec 15, 2010 7:42 am
I'd be happy with that too Che guitarra, nice effort. Highway-star knows I'm only joking about "the chop". Different chopping a rustbucket or beat up beyond repair tintop but it'd be a shame ruining a saveable H.T only to create some kind of wannabe soft top.
Users browsing this forum: No registered users and 34 guests
