It is currently Sun Nov 15, 2026 3:05 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Post Posted: Fri Mar 28, 2008 10:37 pm
steve wrote:
yeap, i just tacked another bit of plate on as a spacer for that difference on the passenger side.
I measured it on my 1.6 block, the difference is 15mm. Looks a bit different on yours? Or it could just be the pic maybe?
Post Posted: Sat Apr 05, 2008 12:40 am
I stacked 3 pieces of 5mm and it works perfect.
My welding was expectedly shithouse though, mind you, I was running a 15A welder off a 25 meter 10A extension lead and I haven't welded for 12 months so I guess that doesn't really make things any easier :oops:
Vehicle: 75 Cruiser
Post Posted: Sat Apr 26, 2008 3:24 pm
made one for the other side, the engine should sit a little lower now. haven't quite finished it yet.
Post Posted: Sat Apr 26, 2008 5:04 pm
Quick change of subject (in a way) but is a engine mount (std) the same on both sides. I should carry some for Casper for the comps.
Vehicle: 75 Cruiser
Post Posted: Sat Apr 26, 2008 5:11 pm
the rubbers/bolts are the same, but the brackets that bolt to the engine are different each side.
yeah bruce, take a spare, and also metal glue, to repair the radiator when the fan hits it.
Post Posted: Sat Apr 26, 2008 5:33 pm
Ok thanks steve. I have one of each from the spare motor we have here for Casper. so I better add them to the parts we gat for the comps. :-)
Post Posted: Sat Apr 26, 2008 5:43 pm
chuck some big zipties around the stock mounts too, helps to stop em overstretching and breaking when upside down :wink:
Vehicle: 75 Cruiser
Post Posted: Sat Apr 26, 2008 5:45 pm
yeap go the zip ties, when my engine mount broke on the first track, we sued big zip ties to strap the mount together and it held all weekend.
Post Posted: Sun Apr 27, 2008 12:44 am
Booty Fab at it's best. Make that 1002 uses for zip ties
Post Posted: Mon Apr 28, 2008 2:13 am
This one replaces the transmission mount. You can see how it drops it down a fair bit, about 45mm all up. I'll be making some engine mounts like Steve has done that will drop the engine by the same amount. Actually, the bits are made and I have the engine on a chain, just need to drop it into the engine bay and tack them up.
One thing to note, there wasn't enough room on the chassis side bracket to use the bolt holes in the chassis like on the stock bracket, so I had to weld studs into the plate.
Post Posted: Wed Jun 04, 2008 6:43 pm
steve wrote:
i put my hand of the mount, the engine doesn't move much, so there's not a lot of movement really, it's just the slight vibration through the whole car.
It probably doesn't help having a broken fan blade either.
It'll just work in with the rest of the vibs that go through the Sierra, gnarled and bent shafts, out of balance wheels and tyres.
Vehicle: 75 Cruiser
Post Posted: Sun Jun 22, 2008 6:14 pm
I finally got around to putting in the new engine mount on the other side.
Post Posted: Tue Sep 09, 2008 6:04 am
Hi everyone, I am new to the site, I made these mount a while back to replace our standard 1300 Sierra mounts (we were breaking them during races). It is exactly the same size as an original mount and bolts to the original block bracket and original chassis mounting position. The mount takes Landcruiser shackle bushes. The driver and passenger side are identical, a standard mount will bolt straight back in if required. They do increase engine vibration to some degree but they have completed two rounds of the Landcruiser Mountain Park Coopers Series unscathed.
Users browsing this forum: No registered users and 16 guests
