It is currently Sun Nov 15, 2026 8:28 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
Poll: What colur to panit it
Shiny black 7%  7%  [ 1 ]
Matt black 36%  36%  [ 5 ]
Army green 57%  57%  [ 8 ]
Total votes : 14
Post Posted: Mon Aug 15, 2011 1:17 pm
4wheeljive wrote:
I think you'll have to get him on the 4" wide back tiers that's what's on mine
Post Posted: Mon Aug 15, 2011 3:09 pm
Yep that would be the one but mine requires a lot less effort ;)
Post Posted: Sat Nov 05, 2011 3:41 am
Ok so time for a bit of an up date.
Ive been riding it to work most mornings un till the front motor mount cracked out, so I thought ok I'll just weld it up and that worked for a while till it happend again so I thought time to do it properly.
Started using the welder at work when gardener offered me a welder that I could have for $5 so I thought what the heck I'll give it a go
Then I got a bit of scrap metal from the work shop next door $2 and proceded to reenforce the whole lot ( I think it actualy worked fairly well for $5)
The I bought some rubber mounts they set me back a fair bit, but I did have to specially get them ordered in the front ones are rated at 80 kg each and the back is at 35 each. If I break this set up I don't what else to do so hopefully it works
Now the next thing to so is get it painted so can put it back to gether and I have to make a new exhaust cause the motor has moved the old one won't fit so a good time to make an expansion chamber for the chopper
Post Posted: Sun Nov 06, 2011 2:50 pm
I had this idea, no rego, cheap fuel low maintenance, high death risk. Ended there
Lj81.
Ke20.
Baleno.
Post Posted: Fri Nov 11, 2011 12:25 pm
Joe wrote:
My mate makes these, would be awesome to chuck a motor in one :D
thas my trike
so is the other one you put up
its getting 1500w of eletrics and 13" mags
and if you have issues with the mounts again shout i'll send you a bolt on adapter plate to suit that frame hell i might have a long pipe laying around home to
Post Posted: Fri Nov 11, 2011 9:39 pm
The trike sounds cool you'll have to put some pics when your done
As for the engine mounts I just really hope it will work this time but I'm having fun with trial and error
Post Posted: Sat Nov 12, 2011 6:42 am
Well had a big day working on the chopper and I ended up painting it mat black and then got it back to gether enough to test out the rubber mounts and what can I say the paint job came out a treat and the motor mounts an epic fail the motor twists about 6 inches with out even turning over so I think I might go back to the original design and hard mount it and hopefully it wont break again cause of the reenforcing but that's for a nother day other wise the misses will be up me for spending to much time in the sheid :crazy:
Users browsing this forum: No registered users and 12 guests
