It is currently Tue Oct 27, 2026 7:18 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
Post Posted: Wed Apr 22, 2009 2:35 am
there go i did a quick side front and top veiw 4 ya of what 2 do 2 mount ya door latch
Post Posted: Thu Apr 23, 2009 12:26 am
hey guys i made up some rock sliders 2day did 1 side 2 see how they would turn out and here they r what ya recon
they r made from 2inch mild steel with a 2mm thick wall
Post Posted: Sun Apr 26, 2009 8:08 am
sliders look awesome, what did you use to notch the tube?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Sun Apr 26, 2009 2:57 pm
hooki, scroll up this page , there's even a photo of it .He. He. He.
Post Posted: Mon Apr 27, 2009 3:54 am
yeah the tube notcher makes life so much easier ay saves ya having 2 worry about it aslong as ya get the right angles
Post Posted: Sat May 02, 2009 5:08 pm
well got 1 of the sliders mounted b4 i have 2 go 2 rugby now all it needs is powder coated
here r some pics so far
p.s have any1 else had trouble getting there doors off they dont want 2 undo
Post Posted: Sun May 03, 2009 1:55 am
thats some good looking gear you have made.
i wish i had the skills & tools to make stuff like that..
Download Sets @ http://www.johnpaul.3leggedcat.net
Post Posted: Sun May 03, 2009 4:05 pm
yep i did doors screws were painted over had to get an impact drill to move em!
[quote="zookieboi"]has anyone really been far even
Post Posted: Sun May 03, 2009 10:33 pm
I was told the best way to get your door screws out IF you will get new ones when you get the old ones out is to get a dremel and cut the head of a screw, Run a deep, thin line across the head and undo it quickly with a big flathead screw driver. The heat from the dremel helps to clear the thread but you have to be quick
Post Posted: Thu May 07, 2009 3:21 am
when i replaced my door screws with hex heads i used a dremal to make 2 flat sides then i just used a shifter to undo it
Post Posted: Thu May 07, 2009 3:27 am
cheers guys ill give it a shot im also making a new bull bar 2 so ill b selling my nudge bar
lesspostingmorewheeling
Post Posted: Thu May 07, 2009 4:15 am
the best way to undo the screws that hold the doors on is weld a nut or bolt to the screw head then undo it with a spanner/socket
Post Posted: Thu May 07, 2009 2:16 pm
i have a #3 Phillips bit that goes in a rattle gun, works 99% of the time.
Post Posted: Fri May 08, 2009 3:07 am
Just go to Bunnings and buy an impact driver set! when you turn it to the undo position and hit the end with a hammer they just come un-done (Note: you need to keep the driver twisted in the direction you want to turn the bolt while hitting it with the hammer) they are easy as to use and cheap as to buy probably around $15-$20 Here's a pic of one incase you don't know what I mean cheers Robb.
Bitumen...Another waste of public funds!
Post Posted: Fri May 08, 2009 3:09 am
cheers guys all good got them off
thanks 4 the info
Post Posted: Wed Aug 19, 2009 12:15 am
or if your not going to use them again use a sharp steel chisle and a hammer
Post Posted: Sun Aug 23, 2009 3:09 am
get an impact driver, lass damage & you can use the screws again
Post Posted: Thu Oct 01, 2009 4:11 pm
Use an impact driver I did. Can pick them up (and a hammer if you don't already have one) at any tool store pretty cheap and if your lucky you will be able to use the screws again. Sorry my bad, didn't realise the post kept going and you'd already got them off
Post Posted: Thu Oct 01, 2009 4:29 pm
impact drivers are shitty, cold chisel only thing that worked on both my sierras.
there is a thread about it on here somwhere
Users browsing this forum: No registered users and 6 guests
