http://auszookers.com/forum/
reinforced radial arm mounts
http://auszookers.com/forum/viewtopic.php?f=14&t=10472
Author:  Ridge [ Tue Mar 16, 2010 10:13 pm ]
Post subject:  reinforced radial arm mounts
awhile ago this happened to my rear diff
i made a template and got some steel cut and welded them on
the mounts are now 10mm thick, they have been on the car for around 6000ks and no problems
Author:  Rusho [ Wed Mar 17, 2010 12:18 am ]
Post subject:  Re: reinforced radial arm mounts
Good work mate 8)
Author:  BlueSuzy [ Wed Mar 17, 2010 11:48 pm ]
Jimny?
( I have recently been studying the Jimny setup.)
Ah not Jimny. Its a Coily! :lol: Just noticed fuel hose guard..Very similar though.
Author:  Ridge [ Thu Mar 18, 2010 9:36 pm ]
yeah its a coily, they do have a few things in common with the jimny, but not a lot.
Author:  Fatzook [ Fri Mar 19, 2010 1:55 am ]
next time it will just tear the diff tube :D
Author:  Ridge [ Sat Mar 20, 2010 4:28 pm ]
hopefully not :oops:
Author:  Saam [ Sat Mar 20, 2010 5:21 pm ]
my little brace from the trailing arm mount to the diff tube still let it twist a tiny bit but made it strong enough :)
Author:  Trojan [ Sat Mar 20, 2010 8:19 pm ]
That's when you just add more steal to the tube.
I have similiar strenghtened mounts, except more added to the back section and the rear mounting hole lowered to turn the whole housing back around level so the pinion flange is still at the same angle as the rear trasnfer output.
Front has been done the same and for castor correction.
Author:  fully sick coily [ Fri Mar 16, 2012 1:15 pm ]
did you have to remove anything from the diff to weld them on or did you do it on the car?
Author:  jonno_racing [ Fri Mar 16, 2012 1:50 pm ]
I pulled mine out.
Author:  Ridge [ Mon Mar 19, 2012 5:41 pm ]
I pulled it out of the car, but left it assembled for welding. The next day i did pull it apart to inspect axles and the centre.
Author:  Rusho [ Mon Mar 19, 2012 6:10 pm ]
jonno_racing wrote:
I pulled mine out.
What about the diff :rofl: :rofl:
Author:  ZookiMonsta [ Thu Mar 22, 2012 6:57 pm ]
Rusho wrote:
jonno_racing wrote:
I pulled mine out.
The Rush brings the funnniiieessss! pompoms
Author:  Rusho [ Thu Mar 22, 2012 7:00 pm ]
ZookiMonsta wrote:
Rusho wrote:
jonno_racing wrote:
I pulled mine out.
It's what I do :mrgreen:
Author:  Fatzook [ Thu Mar 22, 2012 10:44 pm ]
Rusho wrote:
ZookiMonsta wrote:
Rusho wrote:
jonno_racing wrote:
I pulled mine out.
That.....
And shit yourself so bad in the back seat of a moving car, that ALL of the occupants are gasping for air with their heads out the window at 70kph, even though there were 2 PoPo paddy wagons following :gross:
:thefinger:
