It is currently Sat Nov 14, 2026 4:14 pm
Post Posted: Mon Mar 22, 2010 6:24 pm
The supercharger was not working well and had been badly set up so I removed it and decided to start from scratch.
Pulleys didn't line up and it jumped around loose as well as air intake was dodgy.
The ute had a 2" body lift and the pipe work still hit on the bonnet as well as a hole had been cut in the guard liner to clear the bottom mount. :?
I re-drilled the bottom mounting bushes so I could use a heavy bolt and welded up a stronger bottom mount.
The first problem was that the outlet hit on the extractors and I couldn't get the charger to sit up level
I asked for some help from " zookprojectfnq" Chris has great skills and an excellent workshop. He made up a complete new outlet out of steel :goodjob: Image
This moved the outlet away from the extractors and heat allowing the charger to sit up straight
I then needed to make up a new top bracket :oops: Not that proud of what I ended up with but is is strong, clears the outlet and does the job.
It clears the inner mud guard and clears the bonnet without the body lift.
Still need to fit heat shielding
Now to fit an air box and connect it up :woohoo: Can't wait
98 GV
Vehicle: jimny
Post Posted: Mon Mar 22, 2010 6:28 pm
looks like a good fab job. i remember when this was for sale, i thought the install was a little rough, good to see you have sorted it out
Post Posted: Mon Mar 22, 2010 6:36 pm
I believe I have time will tell. A big thanks to Chris for the outlet I was tearing my hair out trying to fit it in up until then. oops what hair don't have any :lol:
98 GV
Post Posted: Mon Mar 22, 2010 8:35 pm
how does it go with the charger much more power? and is it the charger off the 4agze and what carb are you running? it looks like a good set up
Post Posted: Mon Mar 22, 2010 8:42 pm
It was never set up right so time will tell on power. Top end was awesome.
carb is a webber will check on the size, don't know what jets are in it.
98 GV
Post Posted: Mon Mar 22, 2010 9:21 pm
It looks a lot better than it was that's for sure. I'm looking forward to seeing how it goes!!!
Post Posted: Mon Mar 22, 2010 10:11 pm
top bracket looks like it needs to be braced to the extractor studs for additional support.
Vehicle: '96 LWB trayback
Post Posted: Mon Mar 22, 2010 11:11 pm
Sc12 mate? What are your crank/sc pulley sizes? What boost are you running?
Interested to see how it performs on the 1.3 compared to the 1.6
Post Posted: Mon Mar 22, 2010 11:16 pm
Its a 1.6
98 GV
Post Posted: Mon Mar 22, 2010 11:41 pm
My mistake. The mention of a carby through me off.
How about pulley sizes/Boost pressure?
Post Posted: Tue Mar 23, 2010 1:07 am
Looks good Im glad it all worked out in the end.
I bet you cant wait to go for a spin. its been a while
Vehicle: '92 Sierra
Post Posted: Thu Mar 25, 2010 4:36 pm
Nice work. I've been trying to work out what is actually "upright" on my sc12. I've never seen once actually installed on a 4agze. Is it when the two rotors are one above the other vertically?
Are you running the stock G16 crank pulley?
Post Posted: Thu Mar 25, 2010 4:55 pm
Dont the sc12's have a dipstick to check the oil level? If so wouldn't that indicate the 'top'?
Vehicle: '92 Sierra
Post Posted: Thu Mar 25, 2010 5:44 pm
Yeah it does indicated the top but I dond't know what angle it normally sits at. There could be a range of 45 degrees either way you could tilt it. I know it doesnt point straight up when the charger rotors are vertical.
Post Posted: Thu Mar 25, 2010 6:05 pm
I would think if you used a decent sticky oil in the geartrain, it wouldnt matter what rotated angle its on, as long as the driveshaft is on same plane as the engine.
Post Posted: Thu Mar 25, 2010 8:26 pm
main pulley 130mm might be standard?
charger 120mm
Carby is webber the only numbers on it are on the fuel bowl 12R 5765
No boost / pressure gauge was fitted ???? Another job to do :( Hell there wasn't even a taco fitted!! Why would you spend a small fortune building a motor with port and polished head mild cam and hardened valve springs and a supercharger without the essential gauges
Hybird I mounted the charger so that the carby sits level The dipstick is at an angle so will get you a pic if you need.
Installed a air box and intake today will post a pic later, working on a gasket for the top of carb at the moment.
98 GV
Post Posted: Thu Mar 25, 2010 8:45 pm
Keep posting pics mate.
Post Posted: Thu Mar 25, 2010 9:00 pm
The carb seems to be a 34/34ADM weber of a falcon to me.
Vehicle: '92 Sierra
Post Posted: Thu Mar 25, 2010 9:13 pm
charger 120mm
Nice, someone to test my charger calcs sheet for the SC12. It's not like mine's ever going to be finished lol. I just punched it in with those pulley sizes and it came out at 9.2 PSI. I know its just math and doesn't allow for flow restrictions etc. but it would be nice to see how close it is once you get your boost gauge on.
Post Posted: Sat Mar 27, 2010 10:10 pm
air box out of a Holden rodeo 2.8 TD
Would of liked a bit more pipe between carby and air box but not enough room. Still had to move charcoal canister and windscreen washer bottle.
Need a fuel filter mounted just before carby Maybe inline???
Nearly there.........
98 GV
Users browsing this forum: No registered users and 17 guests
