It is currently Sun Nov 15, 2026 2:53 am
Post Posted: Fri Apr 30, 2010 11:43 am
ok after spending quite alot of time with very little results, i have been thinking i might give fiberglassing a go and try to make a one off Back/roof part
thanks to zot_boy for this pic... for the peopl who dont know what i am talking about
basicly a one part roof, back etc.
just a few questions, does any one on here have any experiance in making things like this from scrach?
i have done a fair bit of reserch about it on the net..
basicly i am going to try borow mikes spair B piller etc and set it all out... i was thinking along the lines of useing the factory suzuki roof parts, then useing some plastic carbord (some stuff i picked up off a building sight that they use for insulation? thought it would be handy) expander foam, filler etc....
does any one have any ideas to posibly make this nice and simple...
also how do the standard fiberglass tops hold down? i am asuming its a type of clip? can any one get a pic?
also for the rear window i am thnking of useing a hard top rear window? i do have one somewhere...
Vehicle: 4wd
Post Posted: Fri Apr 30, 2010 12:11 pm
Use perspex for the rear window. Glass would be too heavy.
Watch out or you'll get sued.
Post Posted: Fri Apr 30, 2010 12:14 pm
yeah i have been thinking about both..
there was a few things bought up about perspex shattering?
Post Posted: Fri Apr 30, 2010 1:11 pm
Use Lexcen or polycarbonate. Both are dear but won't break like perspex.
BTW what are you trying to achieve? Better sealed cab? Quieter? Waterproofing?
If its just security, just make a better torneau cover.
Post Posted: Fri Apr 30, 2010 10:44 pm
i love your rear end and roll bar the square sets it off love it
Post Posted: Fri Apr 30, 2010 11:57 pm
basicly all of the above, it gets DAM cold down here in the middle off winter! and i want a ONE pice top that i can just take the whole thing of.
also a bit sick of soft top flapping!
i have been thinking about it for a while now.. i will also be putting around 6inches longer in the cab, the issue i am having atm is working out how to do the corners... i have been thinking about useing plastic carbord for the mould, lining the inside with expander foam, cutting the corner round, then doing the suface with body filler and sanding for a smooth finish!
The only other thing that is left to work out is attaching the actual top to the car.
i am thining along the line of a pice of thin plate around 50mmx20mmx1.6 with 6mm threads welded in to it, and putting that in the center of the actual fiberglass (after around 3 sheets of cloth?) with the threads poking inside??? then some type of latch, or maby some flat plate with nutserts.. this way it wouldnt appear on the outside of the fiberglass?
this is all just ideas atm i like to have everything completley sorted before i start on anything!
Post Posted: Sat May 01, 2010 12:34 pm
The fibreglass canopy over the drivers seat I have, uses 4 brackets, two into the windscreen surround, and two into the rails from A pillar to B pillar.
If you have a look on these you will m10 bolts holes there.
For the rear, you could crew/bolt in using m10 into the back of the B pillar.
My rear canopy bolts down on top of the sides of the styleside if that makes sense.
Post Posted: Sat May 01, 2010 2:01 pm
kind of mate could you possibly get some pics?
i am going to see a guy next weekend who is actually a fiberglasser.. he wants to see the zook and what i want to achieve first hand before he gives me any advice!
should be interesting.
Post Posted: Sun May 02, 2010 8:39 am
Looks like this wont be going ahead.. just organised a maruti roof and back :D
Vehicle: SJ80
Post Posted: Sun May 02, 2010 11:39 am
Much better option (the maruti roof), will save you a shit load of farting about. What did it set you back? I was lucky, mine was free!
Post Posted: Sun May 02, 2010 11:47 am
Lots... but a must have lol
not to bad tho... just have to sort out a rear window and give it a clean up!
Post Posted: Mon May 03, 2010 12:53 am
i made my roof out ally :D havent started the back yet. cost me $140 for the sheet and about $20 for the rivets works very well
87' sierra with 31's
Post Posted: Mon May 03, 2010 3:48 am
I used a piece of ply and put 2 coats of glass and one caot of gel coat on each side
Post Posted: Mon May 03, 2010 10:10 am
i like yours mate but i am 6"2 and have race seats
so i need a inch or 2 extra in the cab!
Post Posted: Mon May 03, 2010 10:11 am
edit i also love your roll bar.. i am going to make one identical
Post Posted: Mon May 03, 2010 11:01 am
No offense to you or the owner of the "roll bar" but that thing is purely for decoration. Welded in bends in the main hoop? and bent rear stays intersecting the main hoop halfway up the verticle plain, and no triangulation......
Only thing missing is chrome and some wanker lights.... :P
Post Posted: Mon May 03, 2010 8:49 pm
Yeah I was worried about lateral movement so I did this.
I have had the car on its side twice and over once. No damage that was with the full exo but
Post Posted: Tue May 04, 2010 11:08 am
you have a removable exo? im in the making of one can you upload some pics so i have an idear where to mount and what size, would be much appreciated :)
Users browsing this forum: No registered users and 12 guests
