It is currently Tue Oct 20, 2026 12:28 am
Vehicle: 1987 sierra tray back buggy
Post Posted: Wed Jul 07, 2010 12:33 pm
fabbed up som drive shafts nothing super special but it solved the problem we had with the driveshafts not having enough extension.
Vehicle: WR250F/Jeep XJ
Post Posted: Wed Jul 07, 2010 12:49 pm
hey mate if you find that they end up shitting themselves, go to the wreckers and find a subaru L series dual range touring wagon and pilfer the rear driveshaft out of them. They are the same diameter as a sierra. You can easily machine the splined shaft and Uni yoke off your old shaft and reweld them back onto the suby one which you can cut down to suit whatever length you need. it's probably even long enough to do a LWB sierra.
This is what I did with mine...120kw 4age and not a prob so far.
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Wed Jul 07, 2010 12:52 pm
You can buy new drive shaft tube, I think ripco even sell it..
Post Posted: Wed Jul 07, 2010 12:58 pm
how do they balance up?
Grease nipples?
Post Posted: Wed Jul 07, 2010 12:59 pm
ah k thanks mate ill keep it in mind. i hope they dont shit emselves coz they are 4 mm wall thikness and square so bucket loads stronger than the standard shafts and there is not much slop in them so if they do break something else will likely have broken first. did a couple og second moment of area calcs on them and they well outrank the sierra round ones.
Post Posted: Wed Jul 07, 2010 1:14 pm
grease nipples tomorrow as will come a run in the lath to see what sort of vibrations i get.
Post Posted: Wed Jul 07, 2010 1:43 pm
Is it seemless SHS? not sure if there is such a thing?
Post Posted: Wed Jul 07, 2010 2:04 pm
matty87 wrote:
bucket loads stronger than the standard shafts .
Good luck with that...
Post Posted: Thu Jul 08, 2010 3:11 am
Seemless Rhs. Yes. You can buy
Telescopic Rhs. Yes. You can buy.
This is only going to be a crawl rig yes? Box will be fine, but any high speed work, mega vibes!
Mate has a box front with lots of slop, works fine in 4wd. (Heavy Lux,crusierdiffs,35's)
Vehicle: 75 Cruiser
Post Posted: Thu Jul 08, 2010 4:02 am
they look good matty! Yeah i reckon something else will break before these do :lol:
I guess if you land them on rocks it might be interesting, but i've seen a few stocker round ones twist,break, corkscrew on rocks, so much of a muchness eh.
PS. how's the rest of the build going? :D
Post Posted: Thu Jul 08, 2010 5:20 am
yeah build is going well got the body all but painted and half doors made engine is nearly running.
the rhs isnt seamless in this case. i ran a couple beads of weld up two sides of the iner tube and ground it back so no slop at all in these ones. and as its a crawler rig i cant see vibrations being a huge problem for us.
thanks for the kind words steve.
Post Posted: Thu Jul 08, 2010 7:15 am
There's guys over here using square shafts, V6 Commodore motors and around 120:1 gearing without any dramas, have never seen one bend and only ever seen one twist :wink:
Zoltan on outers had his front square shaft built in the bush by eye, by a mate of mine. He got up to 150 odd kph at the West Oz Challenge without any real bad vibrations. Built properly they work well.
Post Posted: Thu Jul 08, 2010 10:32 am
got a mate who runs a front shaft the same in his comp lux never had any trouble he won't put one in the rear because apparently if you belly out on a rock or log when the shaft spins it walks it's way along what ever your stuck on which could be worse than being hung up to start with if you were on an off camber hill for example . but give it a go and see what happens . top work
Vehicle: 75 Cruiser
Post Posted: Thu Jul 08, 2010 7:34 pm
put it in reverse and walk the other way :lol:
Post Posted: Sun Jul 11, 2010 8:03 am
where?
Users browsing this forum: No registered users and 30 guests
