It is currently Tue Oct 20, 2026 12:31 am
Post Posted: Mon Nov 01, 2010 8:59 am
I wanted a tacho, but not screwed on - it had to look factory. After many mental prototypes, I dediced to fit a WT cluster into my steel dash, and change over the wiring to the rectangular clips. The only thing then is to, as I understand it, run the additional wire for the tacho. Anyway, phase 1 was to physically mount the cluster, which I did by fabricating a binnacle onto the old dash, then covering it all. I used carbon fibre effect vinyl. Here's how it looks so far
www.bulldogtrimming.com
Post Posted: Mon Nov 01, 2010 9:30 am
do you have any plans for changing the heater controls layout? I have the same dash (1 litre steel dash) and would like the stereo to fit where the heater controls are and to re arrange the heater controls lower somehow, not sure if it can be done with the standard cables etc.
Post Posted: Mon Nov 01, 2010 9:33 am
that is awesome work. 11/10 8)
Post Posted: Mon Nov 01, 2010 10:12 am
Well done mate looks like it came from the factory like that :P
Post Posted: Mon Nov 01, 2010 10:17 am
I hadn't given too much thought to stereo as yet. I'm not sure it could be done using the standard cable but they're pretty straight forward, and if you used the longest ones where the shorter ones are and replaced the longer ones as needed with generic ones I'm sure you could do it.
Post Posted: Mon Nov 01, 2010 10:51 am
:goodjob:
Feel like doing my dash with the wrap? Looks 8) , good job on the cluster as well.
Post Posted: Mon Nov 01, 2010 11:08 am
ZookiMonsta wrote:
:goodjob:
No probs - give a shout when you want it done
Post Posted: Mon Nov 01, 2010 11:14 am
Benchai wrote:
ZookiMonsta wrote:
:goodjob:
:wink: :P
Vehicle: LJ80
Post Posted: Mon Nov 01, 2010 6:19 pm
x2
very neat
Post Posted: Mon Nov 01, 2010 9:42 pm
Never thought there would be dash porn! Nice work. I love the carbon look
Post Posted: Mon Nov 01, 2010 10:56 pm
NICE WORK!!
How much does that carbon fibre vinyl stuff cost?
Post Posted: Tue Nov 02, 2010 9:21 am
shane1992 wrote:
NICE WORK!!
Thanks mate, cost price for the one I got was $23 =gst pm. I've found a couple of other suppliers - not sure of the price from them but I imagine it would be around the same. Considering normal marine vinyl is not much under $20pm it's really good value, and this Nortex brand is without doubt the nicest vinyl I've worked with.
Post Posted: Tue Nov 02, 2010 9:29 am
I can't believe how easy these cars are to work on! Must have been designed and built by men. The dash I fitted was from a 1989 sierra, going into a 1981. All the wires were the same colour, the only addition was the wire from the coil to the tacho. Two spares; one the the 4wd light and the other I can't remember, but all electrical now working without problem. Totally amazing.
Users browsing this forum: No registered users and 31 guests
