It is currently Sat Nov 14, 2026 9:37 pm
Post Posted: Mon Jan 24, 2011 4:56 am
I broke a uni joint in half a bent up the yoke on the tail shaft. I decided enough is enough and decided to build a heavy duty model.
I used the small ends off 2 80 series tail shafts and cut the tube down.
The bolt pattern is the same except the spigot is 1mm smaller and the pinion nut hits. So I pulled the yokes apart and machined them out. I also machined the tube down and weld prepped it for a yoke to spigot in.
now runs cruiser uni joint which are 29 mm instead of the 25mm suzuki ones.. Cruiser tube is 70mmwith a much bigger and longer spline, Suzuki is 50mm
If I break this one I will have serious problems!
Vehicle: WR250F/Jeep XJ
Post Posted: Mon Jan 24, 2011 7:20 am
haha PHAT! Nice work.
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Mon Jan 24, 2011 10:25 am
I'll take 2 thanks...
Post Posted: Mon Jan 24, 2011 11:57 am
Haha great minds think alike :lol:
Mine should be done by thursday :wink:
Post Posted: Tue Jan 25, 2011 8:36 am
make it to strong an something else will break that could be more expensive to fix
Post Posted: Tue Jan 25, 2011 8:59 am
:lol: yep!!!
Post Posted: Tue Jan 25, 2011 9:00 am
Good work tho, like the lil roller thingy..
Post Posted: Tue Jan 25, 2011 7:47 pm
Did it break from axle wrap?
