It is currently Fri Sep 25, 2026 10:41 pm
Post Posted: Thu Jul 08, 2010 12:15 am
Who here have made an orange gun or similar?
This is my latest creation and i thought you boys would be interested :D
Note the one white lid which had to be replaced 8O ( note to self: if the orange is a bit to snug then dont try to shoot it or somthing might brake and throw shrapnel everywhere :lol: )
Post Posted: Thu Jul 08, 2010 12:25 am
PVC doesn't last long when you spray the inside with nasty propellants :?
Keep and eye on the plastic and rebuild it before it takes your hands off.
and potatoes work much better than oranges :wink:
Post Posted: Thu Jul 08, 2010 12:29 am
cheers mate ill keep an eye on it and ill try some potatoes when i find them :D
Post Posted: Thu Jul 08, 2010 12:34 am
potatoes are much better, tennis balls work good too, also if something is too small to fit just wrap it up in paper, it worked for me, used to wrap up a heap of gravel or marbles, voila, just like a shotgun.
my one used to heat up if i fired it too much and the cap would come off and flames would come out the back, lost a lot of arm hair like that.
Post Posted: Thu Jul 08, 2010 1:54 am
The amount of fun to be had is directly proportion to the size of the cannon.
Vehicle: Ducati Monster
Post Posted: Thu Jul 08, 2010 2:47 am
i thought it wasnt the size of the cannon, but how you use it??? :P
Post Posted: Thu Jul 08, 2010 2:55 am
I made mine with 50mm PVC as the barrel and 100?mm as the chamber with a screw cap lid. BBQ piezo sparker. Add potato and aerostart!!!
Shoots ridiculously far. Extra dry bottle are a good fit too :s
Think before you post to make AZ a better place :)
Post Posted: Thu Jul 08, 2010 3:01 am
i have seen them shoot holes in some amazing shit.
Post Posted: Thu Jul 08, 2010 6:08 am
best one i have played with is for golf balls but uses air and a ball valve. pump it up to 90 100 psi and you wont find the ball.
ps don't put air in it in a garage!! went through the plaster and roof tiles. treat it like a gun
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Thu Jul 08, 2010 9:12 am
lol spud guns hahaahah many stories i can tell. 1st of all throw that deodorant away and use taft hairspray that shit is insane. I also experimented with start ya bastard but was too scared to use to much and it fired piss weak. Whenever we went night time 4wding we use to take it and catch oversized toads, and there was this rock wall that we shud shine our spotties on and anihalate (spelling) the poor bastard on. If any one knows brekky creek part of brisbane river, we shot an onion from the little jetty on the river (down from where everyone gets married) and no kidding it got about 5 metres shy from the other side lol. And yes oions shoot far better than spuds, the trick is to get an oversized one position it on some concrete and cut the barrel pipe down onto it so its super snug. And another trick is when u pump the spray in close the lid but let the gases move around for a little bit then spark it.
Post Posted: Thu Jul 08, 2010 10:37 am
wrap as much of the barrell and hand piece in duct tape so if it does shatter you don't get shards of pvc stuck in you every where
Post Posted: Thu Jul 08, 2010 12:21 pm
we used to embed nail punches in the spuds, would shot comfortably through corrugated iron (old fashioned thick stuff) and the spud would simply smash on it!
Post Posted: Fri Jul 09, 2010 2:35 am
Mate has a nozzle on his for the propane cans. extradry bottle, quick squirt of the propane, Kaboom! He has blown up on before experimenting, The object was too big/hard fit and blew up the chamber......
Tooheys new stubbies, lemons, oranges, tennis balls of fire are all good. :lol:
Vehicle: 4wd
Post Posted: Fri Jul 09, 2010 2:57 am
and if you want to scare the crap out of someone use a ball of wool.
Watch out or you'll get sued.
Post Posted: Fri Jul 09, 2010 6:37 am
if you enjoy it blowing up in your face try a little brake cleaner in there., I'd also wrap the entire length of it with at least a layer or two of duct tape or similar, will keep the shards to a minimum when it pops ;)
Tennis balls squeezed full of silicon then left to cure for a few days are good.
get a bit of pipe the same as the barrel then put water bombs in it and freeze them then take the ballon off and u have urself a ice bullet
u can fire it through anything then the evedence just melts
my mate has a air one and we were putting 50mm holes in 12mm ply from 50m away
Post Posted: Fri Jul 09, 2010 9:39 am
fill a tennis ball full of metho and soak it in it then put it down the barrel then use propane as fuel and ignite it fires a wicked fireball
make sure u fire then ova water tho lmfao aussie is to easy to set alight to the country side
also make hot air ballons with a garbage bag a small alluminium cake tray the cheap 1 that are just thicker than tin foil tye to open end of grbage back and light a jiffy and put it in the tray
these are wickd moving targets that u can shoot at with a spud cannon and u can have real fun with them
Post Posted: Fri Jul 09, 2010 9:50 am
Noob here. :D
Please explain how this works.. :twisted: :lol:
Post Posted: Fri Jul 09, 2010 9:51 am
whyat u want to know
Post Posted: Fri Jul 09, 2010 9:58 am
what's what, what goes where etc.
Post Posted: Fri Jul 09, 2010 10:04 am
well on the spud cannon have a look at the pic u push the projectile down the small chamber from the tip using the small bit of pipe u see beside the spud cannon
then u remove the white lid and spray about 3-5 sec of airosole into the pipe where u removed the white lid
quickly put the white lid back on let to sit for a few secs the push the bbq ignighter (the little black botton on the other cap and bang the fuel ignites and expands sending the projectile out the end of the pipe
sometimes it wont ignite on first click so u might have to click a few times
Post Posted: Fri Jul 09, 2010 10:08 am
Hmm, might make one of these. :twisted:
Cheers.
Post Posted: Fri Jul 09, 2010 10:15 am
be very careful u will need a y piece of about 100mm, 2 caps, 1 100-50mm reducer, about 1000mm-1200mm of 50mm pipe, a bbq egnition switch and some blue glue to glue everything inplace apart from where ya threaded cap goes as u need somewhere to put the airosole
if u buy it all at once u might get a real funny look, they will know what ya building and if ya caught with 1 u can be arrested for having an unlicenced firearm
also like said its a good idea to wrap it in duct tape to reduce the effects when it shatter its not a if it shatters its when
Post Posted: Fri Jul 09, 2010 10:30 am
hmm. sounds like I'll be making a few mistakes when plumbing in the
water tank over the next few days/weeks.
Post Posted: Sat Jul 10, 2010 8:56 am
x2 like 2 aluminium sliding door windows at once :roll:
fuck yeah!!
check this site out!
http://www.spudfiles.com/
Go Hard, Trailer Home
Post Posted: Sun Jul 11, 2010 8:51 am
The next step is to make it breach loading so you don't need to spinend on and off, had plans 10 years ago, will have a look.
Vehicle: '95 lwb vitara
Post Posted: Sun Jul 11, 2010 10:31 am
Then throw the hairspray can away, but take the nozzle cap thing off, go buy some camping butane tins (small camp stove, aerosol can size) fit the nozzle, spray and BOOM! 8O Then you won't find whatever you fire, plus it leaves no residue on the inside of the gun, besides the juices or whatever you're shooting. 8)
Post Posted: Wed Jul 14, 2010 11:13 am
I know a bloke (panel beater) that blew his hand off with 50 mm PVC one was no fun in the finish... be bloody careful.
Post Posted: Wed Jul 14, 2010 11:20 am
thats why i suggest not too use anything too hectic as ur explossive gas
Post Posted: Wed Jul 14, 2010 12:42 pm
had an awesome one of these a while ago think its still in the shed somewhere had a valve that you just press the gas to and it filled it up and then just press the button and bang was awesome untill some on complained about me and a friend that where standing at opisit ends of the padock trying to hit each other with our home made devices and got chased by cops over many 6ft fences got away but thought it would be best to put them away for a while haha
Users browsing this forum: No registered users and 33 guests
