It is currently Sat Nov 14, 2026 11:33 pm
Vehicle: LJ80
Post Posted: Sat Feb 20, 2010 2:27 am
cost $65.
1/3 the wieght of the old one.
painted in army camo black seems tough.
small cheap winch.
Post Posted: Sat Feb 20, 2010 2:46 am
Is that an ATV winch ? Are you sure it would be up to pulling you out of a bog hole ?
Bar looks good :wink:
Vehicle: LJ80
Post Posted: Sat Feb 20, 2010 2:51 am
yep. 3500lbs.
i don't plan to get stuck in a bog hole as i try to avoid mud.
Post Posted: Sat Feb 20, 2010 3:29 am
looks good mate. i had the same winch on mine be sure to use the block with it to double the cable back to the zook and its slow but will pull the zook out of just about anything. Just be carefull the motor and gears are not sealed and they like to rust up. Thats what killed mine.
Post Posted: Sat Feb 20, 2010 3:46 am
looks good laurie. x2 on what vwdave says. the one on the back of my SWB
needed to be smashed with a big rock each time i used it. :lol:
Post Posted: Sat Feb 20, 2010 5:56 am
looks good, but the freight to SA might cost more than the bar.. lol
Vehicle: MY2019 Jimny
Post Posted: Sat Feb 20, 2010 1:27 pm
Not taking it to the Cape Laurie?
Vehicle: LJ80
Post Posted: Sun Feb 21, 2010 1:58 am
no not going to the cape.
Post Posted: Thu Mar 25, 2010 1:01 am
hey i really like the bar. can you maybe post some more info on how you manufactured it or pm me some dimensions or plans. also do you know what it weighs? looks neat as.
Vehicle: LJ80
Post Posted: Mon Sep 13, 2010 6:50 am
now i have a dodgy back bar as well.
same pipe same basic shape. sticks out 24mm more from car and is not mounted as strongly. cost about $30 plus $42 for leds .
now i can use both ends as a seat or step could also knock up a jerry can holder ect.
Vehicle: LJ80
Post Posted: Mon Sep 13, 2010 6:56 am
side
Post Posted: Tue Sep 14, 2010 6:43 am
mate that looks madd
im trying to do it myself :)
what did u anchor it too?
Your off ya tree
Vehicle: LJ80
Post Posted: Tue Sep 14, 2010 6:58 am
body mounts on top and towbar mounts below
Post Posted: Fri Sep 24, 2010 10:35 am
those bars r exactly the ones id like on my zook
mud oh gloriuos mud
Vehicle: LJ80
Post Posted: Thu Nov 25, 2010 10:17 pm
the advantages of a cheap bar are you can fix em cheap too
i took it off cut out the bent bit found some water pipe to go full length in the front bar then stuck it back together .
Post Posted: Thu Nov 25, 2010 10:20 pm
WHO did you hit? :lol:
Vehicle: LJ80
Post Posted: Thu Nov 25, 2010 10:30 pm
fella by the name of keven
Post Posted: Thu Nov 25, 2010 10:44 pm
I feel sorry for him.. what a name!
Post Posted: Tue Dec 07, 2010 8:05 am
hey mate did u just bolt the winch on to your bar ?
or to the chassis
Vehicle: LJ80
Post Posted: Tue Dec 07, 2010 9:32 am
front two bolts into bar back two into strengthened chassis cross tube
Vehicle: LJ80
Post Posted: Fri Feb 18, 2011 12:09 am
more cheap bars. picked up some gal pipe.
i still had some of the pipe i made my bars out of that fit over the new stuff just great :D
so i knocked up some (insert animal sounds) cheep n ruff sliders.
all up i guess $24 the pair about half of that bolts.
Post Posted: Fri Feb 18, 2011 12:54 am
Ah so thats what you used them for!
Will be good protection for the rocky stuff.
Plenty more where they come from! The guys has sheet loads.
Users browsing this forum: No registered users and 10 guests
