It is currently Fri Nov 06, 2026 12:42 am
Post Posted: Wed Jul 06, 2011 2:51 pm
hey fellas
been off work for a little wile now so thought id give makin a bar a try,
im self taught with all this so only constructive critisism haha :roll:
any ways this is how it started
did this
didnt like how square it all was so i chamferd the corner
this is what i got so far.
straty (a member on hear) got me a stub axel so gonna buid swing away tire carrier for it also.
also got these coming.
Post Posted: Wed Jul 06, 2011 6:57 pm
Looking good.
Watch where the location of the stub for the swing out carrier will be. I was origionally going to 45' the ends of my bar, but in the end left them square to allow room on the bar for the carrier pivot. I used a 1" pivot pin fixed to the bar and nylon bushes in the carrier to keep the size a bit more compact over a trailer stub/hub combo. I wanted my rear door to open past 90', which it will.
I recon bu the time you allow the pivot point to be placed out far enough for the carrier and rear door to be opened, you may be a tad cramped for room unless the carrier pivot is to be mounted outboard of the bar.
Vehicle: Daisy
Post Posted: Wed Jul 06, 2011 7:49 pm
rick1970 wrote:
Looking good.
If you mount the carrier on the passenger side, you might be able to tweak the clearances so you can still open the tailgate without too much effort?
Post Posted: Wed Jul 06, 2011 8:52 pm
Are those rear lights ADR approved? Cops like to pick on stuff like that. If they are not approved, at least fit some small reflectors on the back of the zook.
Post Posted: Wed Jul 06, 2011 10:15 pm
Looking good mate :)
Post Posted: Thu Jul 07, 2011 12:14 am
i like this. i want one.. :)
Post Posted: Thu Jul 07, 2011 4:04 am
iv messured the coners and the stub will fit in nicley, im gonna put it on the passenger like teracis said, just so i can open full ways and for sierra lean.
with the lights well im in bunbury i dont think any one cares but to be on the safe side i will get some reverse and reflectors happening.
Post Posted: Thu Jul 07, 2011 8:52 am
:goodjob:
Post Posted: Thu Jul 07, 2011 3:01 pm
Interested to see how you have mounted it to your zook. I'm currently fabbing a tube rear bar up with swing away tyre carrier and jerry can holder.
I Have used the outside edge towbar mounting points and also welded tabs on the inside of the chassis tube for extra support i will add pics of this soon if you want.
Conrad
I HATE CYCLISTS!!!
Post Posted: Thu Jul 07, 2011 3:11 pm
Conrad
im not finished with the mounts yet but so far iv used the stock towbar holes.
iv had a few days not being able to work on it but i will be putting tabs on the cross member for the reciever hitch or doing what straty has done and replace the cross member with right angle and bolting to that.
Post Posted: Fri Jul 08, 2011 10:25 am
Teracis wrote:
rick1970 wrote:
Looking good.
True, but i prefered to mount it from the RH side to allow clear access from the LH side. My carrier is also full width and incorperates a jerry can holder, so not much weight (Sierra lean) advantage from mounting from the LH side.
Post Posted: Fri Jul 08, 2011 11:05 am
rick1970 wrote:
Teracis wrote:
rick1970 wrote:
Looking good.
mate have u got any pics of ur rear bar? i was going to make one like the trailtough one but i think u have just changed my mind, one swingaway with both spare tyre and jerry can, sounds good.
Conrad
I HATE CYCLISTS!!!
Post Posted: Fri Jul 08, 2011 12:57 pm
Not the best pic
Post Posted: Sat Jul 09, 2011 3:03 am
that looks the goods, thhough i need to put it on the passenger side due to the tailgate hinges, ill get a pic to explain later
Post Posted: Sat Jul 09, 2011 3:15 am
+ running the spare on the LHS will do wonders for the built in sierra lean
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Mon Jul 11, 2011 8:24 am
hey mate that bar looks amazing!! im loving the rear recovery point! also where did you get those lights if you don't mind me asking??
Post Posted: Mon Jul 11, 2011 12:16 pm
cheers havnt got any work on it latley though :(
jus got them off ebay, im on my phone so cant be bothered seraching but just search for (round led tail lights) should show up.
Post Posted: Tue Jul 12, 2011 7:08 am
they are the same lights i have in the back of my zook they are pritty awesome but when u hit the brakes at night you blind the person behind you :lol:
Post Posted: Tue Jul 12, 2011 8:15 am
oh nice! haha cheers! and make sure you post a finished pic!! :twisted:
Post Posted: Tue Jul 12, 2011 9:12 am
definatly will but got the rellys round so might be a wile :(
Post Posted: Tue Jul 12, 2011 10:22 am
fair nuff.. and i couldnt find those lights :evil:
Post Posted: Tue Jul 12, 2011 2:36 pm
here ya go theres a bit of a range hear http
http://www.ebay.com.au/itm/Euro-Red-Amb ... 5d2ead7d5c
Post Posted: Fri Aug 12, 2011 12:07 pm
Alright finaly got some work done.
proplem was i had absalutly no money but all the time in the world then started work and had no time at all. any way ill put somje pics up tomorrow morning when it aint rainin
Post Posted: Fri Aug 19, 2011 6:35 am
just a quick question for a fabrication noob...
when making the ends of the bar how it tapers up do you just cut out a small section front and back, bend the base up to meet the cut then weld along both edges?
Post Posted: Sat Aug 20, 2011 9:05 am
im noob also haha this is my first fab iv made
Hear you go fellas a little preview, still got the swing away carrier to make though. 8)
Post Posted: Sat Aug 20, 2011 9:07 am
i schamfered the bottem corner then wrapped it all around kinda bad i explainig you might be able to see it in the peck
Users browsing this forum: No registered users and 9 guests
