It is currently Thu Nov 05, 2026 10:38 pm
Post Posted: Fri Sep 09, 2011 8:52 am
Well after too much 4wding on the belly my crossmember was rooted so I made a new one. had to get the grinder out to cut holes to access the old bolts.
Go hard,
Vehicle: LWB Sierra & XL7
Post Posted: Fri Sep 09, 2011 9:11 am
Nice work, personally I'd weld some tabs on the joints for extra bracing.
'92 Vitara & Camper trailer
Post Posted: Fri Sep 09, 2011 10:25 am
Any pics of it fitted? I'll be making a new one for mine soon, as it is also munted, but I'll be using 12-16mm ally flatbar. I can't help but think that your design will sit as low, if not lower than the standard cross member :?
Post Posted: Fri Sep 09, 2011 1:14 pm
I shall take some tomorrow
Go hard,
Vehicle: Suzuki Grand Vitara
Post Posted: Sat Sep 10, 2011 1:15 am
That is well bent.
Did the same on mine.
Post Posted: Sat Sep 10, 2011 4:24 am
Think that'll do????? :?
Post Posted: Sat Sep 10, 2011 5:11 am
you could use FB but I would defiantly add some vertical structure to stop the bending
the three bolt heads sit about 5mm lower than the chassis rails, if I was making from scratch again I would use 30x30RHS. I used 40 because i had it lying around.
I only noticed how bent it was because i had to fix a gasket on the exhaust which started leaking after a bit of a bump. The rubber mounts were on all weird angles.
Go hard,
Post Posted: Sat Sep 10, 2011 5:42 am
Looks good! Better clearance than OEM cross member on the whole.
Post Posted: Sat Sep 10, 2011 5:44 am
Yep. 16mm 6061 T6 flatbar would be stronger than 8mm steel.
Post Posted: Sat Sep 10, 2011 6:35 am
If its was a boring grade of mild steel 6061 t6 would be as strong size for size
Post Posted: Sat Sep 10, 2011 8:10 am
Just because its stronger doesn't meant it will still be suitable
considering moments of inertia
40x40FB
I=880000mm^4
16x40FB
I=164000mm^4
and deflection of a pin-pin beam
delta=(F*L^3)/(48*E*I)
E steel ~235GPa
E Alu ~80GPa
given this the Aluminium beam will deflect ~16x more than the RHS
or in other words put some vertical structure in
Go hard,
Users browsing this forum: No registered users and 7 guests
