It is currently Wed Nov 04, 2026 11:35 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
Post Posted: Mon Sep 26, 2011 9:16 am
i have just put together my air tank for my jimny!! i still need to mount the tank (it fits in where the wheel spanner and jack lives.
i decided to use fire extinguisher bottles because
1 they fit in the right place with the jack
2 cheap
3 have a high enough pressure rating (the one i have do)
it is made up of a vair275c compressor, 2 1litre fires extinguishers, 90psi on and 150psi off pressure switch and 175psi safety valve. i havent put in a drain drain bung as i didnt want to alter the bottle in ANY WAY! as soon as you put holes in or weld them i would be dubious about structural integrity. The fire extinguishers that i have are pressure rated to 2.5MPa (362.6 psi).
i etched the inside of the bottles with hydrochloric acid and have lined them with resin, to prevent rusting.
the biggest problem i had was the reducers from the bottles down to 3/4inch BSP. the bottles use 24mmx1.5mmpitch so i had to get them machined up. but very happy with the results.
the tanks hold enough air to blow out your air filter anf makes pumping up tyres a lot quicker! but that being said i cant fill a tyre from sand to road pressure just from the tank. the compressor has to start up. it would be a lot better with a bigger tank, but i didnt want to take up valuable space.
Post Posted: Mon Sep 26, 2011 9:18 am
Good work mate :goodjob:
Post Posted: Mon Sep 26, 2011 9:33 am
I like it :D
Post Posted: Mon Sep 26, 2011 9:49 am
you need some NOS stickers :lol:
Post Posted: Mon Sep 26, 2011 9:57 am
alexvitara wrote:
you need some blue paint & NOS stickers :lol:
:D That's a hell good idea :lol:
Vehicle: LWB Sierra & XL7
Post Posted: Mon Sep 26, 2011 10:00 am
You clever bastard. :goodjob:
Vehicle: '94 suzuki maruti
Post Posted: Mon Sep 26, 2011 12:02 pm
looking at the bottles and the hoses, i was thinking exactly the same thing 8)
Post Posted: Mon Sep 26, 2011 12:27 pm
That's badass! I wanna make one!
Every problem can be solved with a Ratchet.
Post Posted: Mon Sep 26, 2011 10:40 pm
That is bloody brilliant... I'll tell my friends and family that it was my idea!!
 Profile WWW ICQ YIM
Vehicle: Sold zuk got a Bt50
Post Posted: Mon Sep 26, 2011 11:09 pm
That's what I was planning on doing but can't find any "cheap" bottles ;)
bt50 now but still love the zooks
Post Posted: Mon Sep 26, 2011 11:19 pm
Ask shep, he has a few now :wink:
Post Posted: Mon Sep 26, 2011 11:29 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
 Profile WWW ICQ YIM
Post Posted: Mon Sep 26, 2011 11:32 pm
I've seen that done before. But a single larger tank was used.
Your setup looks very bulky. Where in the car will you be mounting all of that?
EDIT: I re-read your post. Not familar with the jack storage area on a jimny, so I'll have to wait for pics. :wink:
IMO you should make a cradle to sit both bottles side by side. That will save some space for sure!
Post Posted: Mon Sep 26, 2011 11:34 pm
I have a tank a bit bigger than those ones that i'm planning to use for onboard air. I haven't figured out where to mount it though.
The only place I can put it is under the driver or passenger, outboard of the chassis rail. That would make it linds vunerable though I think, hence why it's still sitting in the shed.
Post Posted: Mon Sep 26, 2011 11:37 pm
Just make a bash plate for it. :wink:
Post Posted: Mon Sep 26, 2011 11:38 pm
what about having it under and towards the back of the glovebox?? can still run an air line out the window and its protected from the elements =)
I'd put anything i was attaching on the passengers side too - counter the suzuki lean.. haha
Post Posted: Mon Sep 26, 2011 11:40 pm
With air? :lol:
Vehicle: 1995 swb vitara
Post Posted: Mon Sep 26, 2011 11:41 pm
I have an air tank bolted underneath my vitara
The cross rails on the chassis are easy to bolt to
Using 2" muffler clamps / not sure on jimny
But you can fit quite a large tank in there with no hang
Past the rails - will post pix when I can
Post Posted: Mon Sep 26, 2011 11:42 pm
Dunno if it's me being a pussy or not but I just don't like the idea of compressed air tank inside the vehicle.
I mean it would probably be OK, but if I can fit it somewhere under the vehicle that's my preference. I don't like to take up precious interior space unless I have to either.
Post Posted: Mon Sep 26, 2011 11:56 pm
With air? :lol:
hahaha but its compressed air so it weighs more.... seriously though, the tank and fittings would be a few KG - better to have it on the other side of the car regardless, every bit counts =)
damo - if its only holding lower PSIs and is rated higher i wouldnt see it as an issue in the cab.. take a look at paintball players - running, diving, sliding and smashing 68cu air tanks filled to 4500psi all day - no ones ever died from a tank exploding cos its never happened. People have been injured by their regulator exploding though - but thats cos they used the wrong lube in the internals and it dieselled on a refill.
Post Posted: Tue Sep 27, 2011 12:04 am
Those thanks are designed for all that running aruond though, the neck of an extinguisher is going to be somewhat weak with all the stuff hanging from it
Vehicle: Lwb Sierra
Post Posted: Tue Sep 27, 2011 2:26 am
but its only air, compressed or not, it shouldnt explode, only leak out
Vehicle: Vitara 90'
Post Posted: Tue Sep 27, 2011 2:58 am
Yeah that's true, I saw something like that on mythbusters :D
Plus i also saw a vid of a guys shooting at an lpg tank and when it was punctured it just shot out a mad flame.
Though they can still explode in some situations though I wouldn't worry to much about it as long as you don't put to much pressure in it and you support the neck like what Royce was talking about.
Vehicle: Sierra
Post Posted: Tue Sep 27, 2011 3:05 am
However it does have a safety valve rated at 175psi. So if the valve operates correctly it will not explode.
Post Posted: Tue Sep 27, 2011 3:11 am
"i etched the inside of the bottles with hydrochloric acid" - What benefit does doing this give?
Vehicle: Vitara 90'
Post Posted: Tue Sep 27, 2011 3:26 am
Yeah that's true, I was thinking worst case scenarios. Just so we are clear, I think it's a good idea.
Post Posted: Tue Sep 27, 2011 4:40 am
Helps the resin bond to the tank walls.
Post Posted: Tue Sep 27, 2011 5:21 am
That looks cool :)
Might need to find a big 9kg bottle :P
Post Posted: Tue Sep 27, 2011 6:26 am
no theyre not... theyre all just a standard air tank with a standard threaded end... paintball manufacturers took the tanks and modified their own regulators to run a paintball marker. All im saying is that the tanks are tougher than most give them credit for, and its usually the fittings that leak/cause issues, not the tank itself.
Post Posted: Tue Sep 27, 2011 6:35 am
So they all run around with pumped up fire extinguishers powering them things do they?
All pressure tanks are not created equal, look at the difference in the neck
