It is currently Sun Nov 15, 2026 2:52 am
Post Posted: Tue Aug 26, 2008 6:01 pm
hi all
ok i went and had some big tyres added to the Gv and noticed the front would rub when turning corners. i have not worried about this as i am lifting the front too but when cleaning the gv the other day i noticed a metal bracket holding the bottom of the wheel arch to the bumper
1 pair of pliers and a quick twist has supplied an inch of clearance :D
and full lock as you can see it makes a big difference.
just a quick Mod for all Gv owners
tim
Post Posted: Tue Aug 26, 2008 11:27 pm
be carefull lol my back wheel grabed onto of them them brackets and rambed a big bit of metal through my tyre. :(
[img]http://img295.imageshack.us/img295/7474/plate
Post Posted: Thu Aug 28, 2008 3:39 pm
How are your tires in the rear wheel arches, Tim?
I found them to be more of a problem than the fronts (before I lifted it) when I had 235/70's fitted. I did the Oodnadata track, with a little bit too much weight on board for the stock suspension, and shoulder of the right rear tire got cut up by the metal lip at the top of the wheel arch, and was also rubbing on the plastic at the front edge. I took both the rear wheels off and gave the metal lip a bit of a massage with the rubber mallet to give a bit of extra clearance. The tire has made its own clearance on the plastic bits...
Post Posted: Thu Aug 28, 2008 7:32 pm
hi mate
sofar no issue with the rear and i have had it fully loaded when camping!
( 50mm coil spacers in the rear ) but whenthe tyre is flexing up into the rear wheel arch she just touches
Post Posted: Fri Aug 29, 2008 2:57 pm
He he he, glad to see I'm not the only car park rock crawler.
