It is currently Tue Nov 03, 2026 1:49 pm
Vehicle: 75 Cruiser
Post Posted: Sun Sep 14, 2008 11:02 pm
My old tube doors were donated to Crazy Craig so we made some more for mine. The old ones had a sliding bolt action to lock them. We made these a little different using the standard Sierra windscreen clamp down latches. The latches are up and out of the way so not much chance of ripping them off.
32mm tube. Tags welded on with holes in them to hold the rivets in the mirror stainless sheet.
The standard Sierra windscreen latch. The screw that holds the B pillar in goes through one of the holes and we just chucked a tec screw in the other hole, but basicly sits on that little flat plate for the B pillar.
Also have the peice of right angle as a door stop that screws the existing door latch holes.
It uses the standard Sierra door hinges and holes.
now we have matching doors, isn't that sweet
pics from the test track
Post Posted: Sun Sep 14, 2008 11:05 pm
gunna beat up these ones :)
I can put a nutsert in where you have the TEK screw if you ever want to get fancy
good thinking on the latch, out of the way there
Vehicle: 75 Cruiser
Post Posted: Sun Sep 14, 2008 11:12 pm
it's a tech screw royce, coz it's about as tech as we're gonna get :lol:
nutserts sounds fancy.
The latch is incredibly easy to operate aswell, you just use your inside arms to reach across and do it up or undo it. And once closed it holds it very firm. Not sure how it'll go if it cops a bit hit, it might go out of line, but ya get that i suppose.
Post Posted: Sun Sep 14, 2008 11:28 pm
aaron has the same but on the outside, its a bit twisted up from use so gets a bit stuck now, no doubt he will come up with some air operated thing soon enough :)
Vehicle: 75 Cruiser
Post Posted: Sun Sep 14, 2008 11:32 pm
yeah i remember him having the latches on the outside, but i thought they'd be too exposed and get wiped out.
Post Posted: Mon Sep 15, 2008 1:23 am
looks really good steve. My mates planning to make some tube doors for his zook soon. But I think he will probably run the stock latch...
So is it ready to run/finished? whats the next event on the agenda?
Don't worry, It's only a suzi...
http://www.auszo
Post Posted: Mon Sep 15, 2008 2:18 pm
looks pretty good bloke.
is there much of a chance of the lock/handle unclipping and folding down while driving?
Web wheeler extroadinaire
Post Posted: Mon Sep 15, 2008 3:15 pm
I doubt it, they hold the windscreen down pretty hard.
Post Posted: Mon Sep 15, 2008 7:41 pm
furry muff. just a thought!
i was only thinking that if he was driving, it might vibrate and pop off.
none the less looks good steve.
Post Posted: Thu Apr 16, 2009 12:59 am
How many metres tube would you need for each door would you guess?
Vehicle: 75 Cruiser
Post Posted: Thu Apr 16, 2009 12:40 pm
guessing... 2 1/2 metres? I'm at work, car is at home.
you'd have to measure what you need for your design.
Users browsing this forum: Google Adsense [Bot] and 14 guests
