It is currently Wed Nov 04, 2026 8:09 pm
Post Posted: Wed Jan 25, 2012 6:38 am
Made a extended bracket for my Load sensing proportioning valve (lspv). Its the spring attached to your rear pumpkin.
When you raise the suspension of a Jimny to regain proper brake balance this is necessary. The final positioning should see the axle housing end of the spring being slightly higher than the valve lever end. The amount to lengthen it by is the same amount the suspension has been raised. The lever should be in a relaxed position when finished.
I have seen one advertised on the Jimny bits site but to save $30 made one myself from a bit of gal shelf brace I had sitting around. Really easy to make, took about a 1/2 an hour including fitting etc. Brakes are much better balanced front-to-rear now.
The finished item
Pinched this manual page from MOAG's thread.
Post Posted: Wed Jan 25, 2012 7:05 am
Will have to make one of these up. Cheers Zukenutter. :goodjob:
Post Posted: Wed Jan 25, 2012 7:10 am
Timely :wink:
Post Posted: Wed Jan 25, 2012 7:25 am
Good work Mr nutter :P
Don't you have ABS?
Post Posted: Wed Jan 25, 2012 7:37 am
do abs jimnys not have these?
Post Posted: Wed Jan 25, 2012 7:38 am
Nope! :)
Vehicle: 2001 Jimny M13A
Post Posted: Wed Jan 25, 2012 8:19 am
:lol: Yours looks so shiny compared to the one i made..
Good job Mr Nutter.
Post Posted: Wed Jan 25, 2012 9:15 am
ive been meaning to do this for ages....
can you notice the difference a heap? or is it fairly minimal?
MY BUILD THREAD HERE!!!!!
Post Posted: Wed Jan 25, 2012 9:24 am
Does your back breaks lockup during hard breaking :wink:
I didn't do the before and after thing..
Post Posted: Wed Jan 25, 2012 9:35 am
Nice work there mate :)
Post Posted: Wed Jan 25, 2012 12:18 pm
My brakes are definitely much better now. Even in the current wet conditions I have been able to hit the brakes much harder than I used to with no lockup.
Post Posted: Wed Jan 25, 2012 8:39 pm
Don't you have ABS?
:helloo: NOPE!! :D
Is why I could do this
EDIT: Oh you mean brindog :oops:
Post Posted: Thu Jan 26, 2012 3:08 am
^^ :lol:
nah 07. 8)
08's when abs started. Hate to have ABS :thefinger: :lol:
Post Posted: Tue Feb 07, 2012 8:48 am
I just disconected mine and zip tied it up out of the way, works fine and have had no problems with rear lock ups
Kyzer
Post Posted: Tue Feb 07, 2012 8:54 am
Kyzer
I think that's a better option than just raising the suspension and leaving it connected. I'm not sure exactly which way the bias is meant to go but I found with it still connected that I had too much bias towards the front during heavy braking.
Post Posted: Tue Feb 07, 2012 12:23 pm
I adjusted mine, looks still connected, but brake bias is contant.
It was a real pain having variable rear bias down loose steep hills.
I now have good brake balance, that is predictable.
But this is an off road only solution ;)
I like the idea of an extension to allow for lift,
smarter option for legality and safety.
Post Posted: Tue Feb 07, 2012 12:31 pm
I had an in-cab choke cable in my old Jimny rigged to the lever so I could play around with the bias. Never really used it though :oops:
Post Posted: Tue Feb 07, 2012 12:38 pm
Mine being a LWB it is quite heavier at the rear than a swb softy,
and I carry a bit of weight in the rear, too,
so it may be a different story for everyone else.
Vehicle: 2000 Jimny
Post Posted: Mon Jul 07, 2014 11:04 am
sorry for old bump.
i tried to make an adjustment bracket on the weekend but don't appear to have had much success (actually made 2, one slightly different for more tension).
basically chucked the bracket in & had someone jump on the tow ball to see if any adjustment occurred & it didn't. then removed the spring & had them apply the brake to see if anything would happen & it never (had the hand brake off & the wheels chocked).
does any one know how the valve is meant to work ? i'm guessing when the brake is applied the lever will try & open to the left, but the spring will restrict it based on the ride height of the car. is this correct or am i missing something ??
thanks for your help as always.
Post Posted: Mon Jul 07, 2014 12:01 pm
as you add more load to the rear, it adds more rear brake bias. so the more you compress the rear end the less tension is on the spring letting the arm move which lets more pressure to the rear brakes.
what you are wanting to do is to get it back to the standard position at ride height.
Vehicle: 2000 Jimny
Post Posted: Mon Jul 07, 2014 1:35 pm
well when i even remove the spring completely & depress the brakes the valve doesn't do much more than move a couple of mm, yet if i move it by hand i can move it over an inch. could it be faulty or possibly not bled properly ?
Post Posted: Mon Jul 07, 2014 1:49 pm
On a Jimny, the standard position at the point that the springs attaches to the axle bracket is slightly higher than where the spring attaches to the ISPV lever (spring is almost parallel to the ground. On a Jimny it actually pulls on the lever as you load the rear or as you brake hard. Engagement of the valve only requires a small amount of lever movement. When there is no load, the spring should be slightly loose, when you apply load in the rear the sprung mass moves down toward the axle, thus stretching the spring and pulling the lever.
When I did mine I had a stock Jimny alongside to work from. Worth climbing under a stocky so you can see how they look when stock.
engagement is only a couple of mm movement, the rest is just free play
Vehicle: 2000 Jimny
Post Posted: Mon Jul 07, 2014 2:39 pm
thanks for that nutter, looks like my second attempt at a bracket was fine, had a slight bit of free play & had the spring sitting slightly upwards. will have to refit it =)
