It is currently Sat Nov 14, 2026 10:45 pm
Vehicle: 2002 Jimny
Post Posted: Sun Feb 05, 2012 12:58 am
Just wondered if any of you guys down under have made your own snorkel. If so pictures and description would be very much appreciated.
Ian
Ian.
Post Posted: Sun Feb 05, 2012 1:25 am
I've made one from 3" industrial vacuum truck suction hose. It's bloody strong and takes hundreds of kg's to fully collapse, I can hardly budge it by jumping on it. Beauty of it is that being not completely rigid it doesn't damage panels badly when you lean it against a tree and springs right back afterwards without any damage. It's not the prettiest snorkel but I rate form over function and it cost me nothing. Search my build thread under "the scrub tick" if you want pics.
Post Posted: Sun Feb 05, 2012 9:11 am
My PVC snorkel worked a treat!
Vehicle: 2002 Jimny
Post Posted: Mon Feb 06, 2012 4:34 am
What diameter pipe did you use. What did you fit on top?
Ian.
Ian.
Post Posted: Mon Feb 06, 2012 5:57 am
I think it was either 65 or 50mn. I just used a 45" bend on top facing backwards
Post Posted: Mon Feb 06, 2012 8:33 am
And first tree you come close to it goes BANG! and explodes
Post Posted: Mon Feb 06, 2012 10:40 am
I've never been in such a ridiculous spot that will cause harm to me or my vehicle. Mind you the snorkel never caught a tree/bank anyway. And if it did you would be more worried about the front guard/panelwork! Also If it did happen I'd much rather a $20 snorkel go pop then a overpriced plastic one!
Post Posted: Mon Feb 06, 2012 11:37 am
I had a local exhaust shop fabricate this 2 1/2 inch stainless steel snorkle. I then had it polished. It's fixed to the "A" pillar with the use of nutserts.
This is the snorkel un-polished
The 2 nutserts in the "A" Pillar
The snorkle after being polished
Post Posted: Mon Feb 06, 2012 1:19 pm
I'm a PVC man also. I had a snorkel made up outta exhust pipe and the first trip out with it, reversing against a tree and ripped the snorkel out thru the windscreen fucking the frame and glass and the snorkel.
This is after it has been straightened.
I then went pvc. 65mm from plumbing shop. 1 90 degree bend out of the guard and 2 45 degree bends. Total cost about $50. I have it screwed to the windscreen thru a cable tie so if it desides to go bang again, no windscreen damage.
I also didn't glue the fittings together, instead used a bit of silly coon to seal the outside of the joins up so if I do bust the pipe, ya only need to get new pipe, not joins aswell.
Vehicle: Ducati Monster
Post Posted: Mon Feb 06, 2012 3:27 pm
rpmwrx wrote:
mate that looks fucking horn, very cool 8)
Post Posted: Mon Feb 06, 2012 7:30 pm
Here are some that I have made.
Vehicle: 2002 Jimny
Post Posted: Mon Feb 06, 2012 7:46 pm
Must say, I love the polished S/S one and "fatzooks one. What did they cost to get madein S/Stee.
Ian.
Ian.
Post Posted: Tue Feb 07, 2012 7:04 pm
i had a pvc one....and had 2 spare ones in the back...never again....they dont just break they explode and end up everywhere!
the one i have now is like a bigger vacume cleaner hose....was been lent on crushed on and loves it!
back in a built sierra!
Vehicle: Suzuki sierra
Post Posted: Sat Jan 05, 2013 11:51 pm
How much did it cost u to get made
Post Posted: Sun Jan 06, 2013 6:04 am
This is what mine turned out like viewtopic.php?f=14&t=2332
Scrawn wrote:
Well, finally got a chance to finish off my snorkel today. The paint left a little to be desired but the rest looked ok for a throw together job.
This is the mounting bracket on the 'A' pillar
Vehicle: 2006 JT627 Grand Vitara
Post Posted: Sun Feb 10, 2013 6:02 pm
rpmworx> HOw much did that snorkel cost ya?
Users browsing this forum: No registered users and 13 guests
