It is currently Sat Nov 14, 2026 9:29 pm
Vehicle: 75 Cruiser
Post Posted: Fri Oct 17, 2008 10:04 pm
yer yer i'm sure everyone will think it's dodgy.. but it's for offroad use only.... and it works.
I needed a 100mm longer shaft, so i cut two shafts and sleeved it with some tube. I drilled some holes along the standard shaft and once the tube was inside i welded in the holes, basicly connecting the outside tube to the inside tube.
This is about 100mm longer than standard.
Post Posted: Fri Oct 17, 2008 10:44 pm
For a gain of |<-------------------------->| much may i ask why a drive shaft spacer didnt do the trick? Or does it already have one?
Ps welds look ok 8)
Dan
Post Posted: Fri Oct 17, 2008 10:50 pm
yeah how long is the extension? it looks less then 1 inch
Vehicle: 75 Cruiser
Post Posted: Fri Oct 17, 2008 10:53 pm
now i remember. It's actually two different shafts. i purprosly cut them both that length , so i had a space to weld them to the inner tube.
PS. where the cut on the long side of the shaft is, is where the shaft ended.
It's a front shaft with a rear shaft end welded on,.. I'll get a measurement tomorrow for the hell of it.
Post Posted: Sat Oct 18, 2008 3:13 am
That seems fine. Its a trail rig, why would you bother buying a spacer?? Doesn't need to be perfectly balanced or anything. I would even go as far as RHS shafts on a trail rig. When your going slow they don't need to be balanced.
Post Posted: Sat Oct 18, 2008 12:01 pm
A mate of mine uses a RHS shaft in the front of hil hilux. works well but it does seem to flog out the uni's alot quicker
Post Posted: Mon Oct 20, 2008 2:40 pm
another trick is to get some heavywall pipe the right diameter and replace the whole lot, then its more impact resistent too
Users browsing this forum: No registered users and 13 guests
