It is currently Sun Nov 01, 2026 3:23 pm
Post Posted: Tue Jun 05, 2012 11:24 am
I'm fixing up a sandblast cabinet and need to put a new light in it. I have a 600mm flouro batten fitting but i'm sure the tube will get smashed if it's not covered. I was going to track down an external 600mm fitting with a sealed cover, but just putting it out there in case someone has a better idea!
Post Posted: Tue Jun 05, 2012 11:49 am
If it had a plastic cover over it it should be ok. Just keep the pointy end of the gun towards the work and not the light
Post Posted: Tue Jun 05, 2012 12:39 pm
As above. A thin sacrificial polycarb cover over the light should be fine. Just replace when it gets too dull.
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: vits
Post Posted: Tue Jun 05, 2012 2:49 pm
Don't forget to earth the cabinet.
Post Posted: Tue Jun 05, 2012 10:41 pm
Make a cover for the light out of the cheapest, easiest to replace material you can get.
When you fit a new piece put tape over half of it and when you can't see any more take the tape off and you've doubled the life of the 'glass'.
Vehicle: 96 vit hardtop
Post Posted: Tue Jun 05, 2012 11:43 pm
Yep. My cabinet is like that ^^^^
Post Posted: Tue Jun 05, 2012 11:45 pm
But I used double sided tape and Stck a plastic flexible Perspex over it. Then I replace the Perspex when it's rooted
Have the same over my glass screen
Users browsing this forum: No registered users and 9 guests
