It is currently Sun Nov 01, 2026 2:36 pm
Post Posted: Sat Jun 09, 2012 12:51 pm
I have seen someone post a pic of their divider they made up out of marine ply.The divider is for a soft top to make the front cab as "secure" as can be and reduce noise and wind bufffeting from the rear .
Does anyone have specs for the odd shape of the area that is behind the seats and where the divider goes? I was thinking of getting a large sheet of butchers paper and scribing it on as a template ?
Vehicle: 82 Sierra SWB soft top
Post Posted: Sun Jun 10, 2012 7:56 pm
IMO grab some cardboad (try the back of safeway or coles and just ask the workers for a big bit) cardboard will be able stand up and hold its wieght unlike butchers paper which would just flop around, will make it alot easier. I am shortly going to make one for my swb sierra and will use cardboard.
Post Posted: Mon Jun 11, 2012 12:10 pm
Tried plastic sheeting = Bastard.
Tried card board = Semi bastard ,but a basic template .
At least ive got a rough template now but will have to trim up a few practice ply sheets before a nice tight fit is found ! Once I have a fited rear divider, I will fit a perspex window into it so I can see the trafic im holding up !
Vehicle: 03 Jimny
Post Posted: Mon Jun 11, 2012 1:42 pm
viewtopic.php?f=14&t=19730&start=30
some thing like this, first pic on page.
They did put the window in upside down though.
Post Posted: Mon Jun 11, 2012 8:51 pm
Or put it that way to make better use of available vision with the window that way.
Post Posted: Wed Jun 13, 2012 6:58 pm
3mm mdf sheet is the bomb for templets
U can cut it with a knife, saw, drill it, sand it
Its strong but can be bend
Vehicle: Coil Sierra
Post Posted: Wed Jun 13, 2012 10:39 pm
I used cardboard double thickness.
viewtopic.php?f=14&t=19191&hilit=marine+ply
Mine was half the height you want to make up, but u get the idea.
