| PTO transfer case http://auszookers.com/forum/viewtopic.php?f=14&t=33925 |
| Author: | caboose [ Fri Jul 06, 2012 9:40 pm ] |
| Post subject: | PTO transfer case |
Here is something i found on a Danish suzuki forum just thought is was interesting way to make a non pto transfer case into one Extra outlet on the distributor gear box by jimmi a "January 21, 2012, 12:01 Feel like getting mechanical games in the back of my suzuki, so I try it: input shaft from 410 so it can be used to 4,16:1 gearing and the piece of the bottom wheel to front wheel drive the base shaft drilled out, and crimped on the input shaft is tig welded by a hole drilled in the distributor gear box housing threaded holes drilled and machined flange of between the disc rotated 25 mm aluminum plate turned and drilled new larger bearing-mounted housing with the shaft of the combined with front-wheel house viewed from another source now this is not mine. just found it on the above website and translated it in Google translator |
