It is currently Mon Nov 02, 2026 4:09 pm
Vehicle: Sierra & Jimny
Post Posted: Tue Jul 10, 2012 4:03 pm
I bought these LED's from eBay & used some checker plate to mount in original bar. I want to eventually use them in a custom rear bar...who knows when that will be!
Vehicle: 82 Sierra SWB soft top
Post Posted: Tue Jul 10, 2012 6:00 pm
Not to bad got a shot at night? how much they set you back?
Post Posted: Tue Jul 10, 2012 6:06 pm
They don't look like they have a reflector? - Whilst the lights themselves might be ADR approved, your car isn't ADR approved without red reflectors on the rear.
Just something to consider.
Vehicle: 1.3 Tin Top
Post Posted: Tue Jul 10, 2012 6:54 pm
You can get small reflectors from supercrap, dirt cheap. makes it legal and unless u know ur mechanic well it wont pass rego.
Post Posted: Tue Jul 10, 2012 7:04 pm
X2 Trypt
Also remember to fit resistors or a LED flasher unit* to ensure the flash speed is correct.
*A note here. LED flashers are sold as "motorcycle" flashers. I don't actually believe they are legal for use in a road car, so you might not pass rego with one. Here's the reasons:
1) LED flashers aren't load sensitive, so if one of the incandescent bulbs still in the system fails, there's no indication as the flasher flashes the same rate regardless of what's hooked to it
2) There's no audible "click" when the indicators operate. This is a requirement, and you won't find a car without an audible click.
I use an LED flasher. When I took my car originally for a RWC, it failed for indicator flash speed. I used resistors initially, but subsequently swapped to an LED flasher.
Just some stuff.
Vehicle: 1985 Holden Drover
Post Posted: Tue Jul 10, 2012 7:12 pm
Like Steve said i found an LED flasher to be alot easier to be honest. This is the one i bought and its pretty close to the original speed
http://www.brightlightautoparts.com/NEW ... ORIES.html
I got the CF13JL-02 im pretty sure :)
1989 WT Sierra.
Post Posted: Tue Jul 10, 2012 9:36 pm
Cost $44.50 delivered for the pair, bought them from brightlightautoparts on eBay, I bid on them, pretty happy with the price.
No reflectors...I just haven't had a chance to put some on...might visit SuperSteep tomorrow.
I bought an electronic flasher from eBay: http://www.ebay.com.au/itm/180895413118 ... 101wt_1139
Really poor build quality though, I had to remove all the components from the board, and re-solder them directly to each other, I also had to swap two pins around for it to work correctly...what do you expect for $2 though. This unit has an audible click as well...i'd say it is right on the limit of legality though.
Some night pics...lets just say they are bright!
Vehicle: Sold zuk got a Bt50
Post Posted: Wed Jul 11, 2012 8:52 am
Can someone confirm what is the right model because im going to need one of these as well
Oh and nice lights by the way
Post Posted: Wed Jul 11, 2012 8:56 am
X2 Trypt
Just some stuff.
A mates missus has a little Mazda 3.. All the indicators are LEDS on it and when flashing you can hear a tick tick.
There is a friggin speaker under the dash to make the noise.... 8O :!:
Post Posted: Wed Jul 11, 2012 9:46 am
Hey mate just checked my invoice I had saved and yes this is the right model :)
1989 WT Sierra.
Vehicle: Suzuki Sierra
Post Posted: Wed Jul 11, 2012 11:46 am
want33s wrote:
X2 Trypt
Just some stuff.
Funny, most new cars don't have flasher cans, they use a clicking noise through the speakers to make the noise. Perhaps the dealer can reprogram the noise down a little with the factory scan tool.
Builder of street legal bacon sandwiches
Vehicle: ***
Post Posted: Wed Jul 11, 2012 4:27 pm
Don't really like them on the original bumper.
But farout they're bright.
Will look good on a custom rear bar i think. Cant wait to see it
Post Posted: Wed Jul 11, 2012 5:27 pm
Does it have to be a tick or can it just be any audible noise? It would be very easy to wire a buzzer in.
Post Posted: Wed Jul 11, 2012 7:17 pm
Afaik the tick comes from the relay anyway doesnt it?
1989 WT Sierra.
Vehicle: 89 swb sj50 widetrack
Post Posted: Thu Jul 12, 2012 12:06 am
not bad for led taillights. i will post picks of my new led lights i have custom fitted to my sj50 rear bumper. you think the above are bright !!!
also be a bit carefull with the cheaper led tail lights as i am in the trade and have had a them just short out as they are not super water tight.
mine cost $300.00 for indicators and brakes
Post Posted: Thu Jul 12, 2012 12:38 am
Ok the ADR states the if a bulb fails the driver must be made aware, this is done by either a audiable or visual indication. That means the clicking get faster or the flashing gets faster. (this was back when I was in the industry - 8 years ago) that means if you had a warning light on the dash or a buzzer that detected a blown bulb, failed LED that would suffice.
Remember most Roady/ Safety Cert guys don't really know the rules, they just know the norm therefore if something is different they're lost.
Post Posted: Thu Jul 12, 2012 1:02 am
Haven't we just concluded that LED relays don't click?
It's not like they're going to remove a bulb/unplug a light to test it anyway. You're just a bit fucked if you get caught on the road with a dead light.
Post Posted: Thu Jul 12, 2012 1:13 am
I've been driving around with a blown headlight bulb for weeks. I even had a copper wave to me at the lights the other night. Rolled down his window to tell me I had a light out. Funny thing is, so did he :lol:
Checking your lights are working is just part of owning a car. Non-clicky relay should be fine, just ve vigilant. :wink:
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Jul 13, 2012 6:18 am
X2 Trypt
Just some stuff.
U can buy an led flashing relay that will swap ur old indicator relay .plugs strait in and it always flashes the same speed matter what and u can hear it tick still .mine was like $15-$30 off eBay ,cos I had the same problem
Green? greeeen is nice !
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Sun Jul 15, 2012 7:51 pm
In Nsw it doesnt have to 'click' just as long as the indicator lights on the dash work then its all good
If it ain't Broken, You ain't tryin hard enough...
Post Posted: Sun Jul 15, 2012 8:54 pm
Dont know whats clicking when my indicators are on then?
1989 WT Sierra.
Users browsing this forum: No registered users and 18 guests
