It is currently Sat Nov 14, 2026 11:39 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2  Next
Vehicle: Jimny 99 2" lift, 31s etc
Post Posted: Tue Jul 24, 2012 7:34 pm
I have seen a few on here but cannot find any now! I want to install recovery points on the front and back of my sierra and need some photos to help if possible! Thnx
if u don't get stuck u ain't trying hard enough
Post Posted: Tue Jul 24, 2012 7:44 pm
What's wrong with the ones there now?
Post Posted: Tue Jul 24, 2012 8:12 pm
Are they strong enough for pulling out cars or being pulled out etc?
Vehicle: 1985 Holden Drover
Post Posted: Tue Jul 24, 2012 10:23 pm
Id say if they are put on there from stock then they kinda have to be from some point of view? :lol:
1989 WT Sierra.
Post Posted: Wed Jul 25, 2012 3:54 am
don't use the factory rear tow point that's bolted on with the two bolts. I've seen a couple of them break off and it's bloody dangerous when they do. Those recovery hooks which I think you can buy from supershit mounted correctly to the chassis or strong front/rear bar can do the job.
When it comes to recovering other vehicles with a sierra my rule is usually nothing bigger than a suzuki if they are really stuck. Trying to pull out a heavy pos like a patrol will usually be unsuccessful and cause damage.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Vehicle: 1.3 Tin Top
Post Posted: Sun Jul 29, 2012 2:29 pm
And you will head but the dash and or steering wheel if u try to snatch something like a patrol... its not nice
Vehicle: 2003 Jimny Auto
Post Posted: Sun Jul 29, 2012 6:06 pm
Been there done that
It hurts.
Car OK but more lucky than smart.
Post Posted: Sun Jul 29, 2012 7:04 pm
Is there anything wrong with chucking a chain around the tow bar
Post Posted: Sun Jul 29, 2012 7:10 pm
Are you for real?
Post Posted: Sun Jul 29, 2012 7:16 pm
i mean the actual bar not the ball... if u can get those rated hitch tongues with a shackle on them? doesnt that mean the tow bar is strong enough. IDK thats why im asking
Vehicle: '94 suzuki maruti
Post Posted: Sun Jul 29, 2012 9:55 pm
http://www.bushranger.com.au/recovery_hitch.php
Vehicle: 85 Suzuki Sierra
Post Posted: Sun Jul 29, 2012 11:27 pm
Here are my front ones:
I had to grind a bit of notch out of the top of the hooks so they are up high enough for bolt holes to go through the chassis. The only improvements would be reinforcing the inside with bits of pipe around the bolts, mine have been on there for years like that no problems though.
On the rear I did have some hooks bolted to where the stock rear bar bolts onto, but snatching people bent them upwards and warped the metal they were attached too overtime, as there was not a lot up upwards reinforcement. Now I have a rear bar bolted to the chassis each side with a hayman reese socket as per the pic above and its great :).
Orange LWB Sierra
Post Posted: Mon Jul 30, 2012 7:27 pm
Sierra tow bar is only rated at 400kg so unless u r snatching a quad not a good idea to pull off that
Post Posted: Mon Jul 30, 2012 7:34 pm
:oops: oh... i will no longer be using tow bar
Vehicle: '84 LWB 1LTR
Post Posted: Mon Jul 30, 2012 10:07 pm
I just made this up for my LWB on the weekend 50mm pipe attached to the chassis with 5mm plate. All up with led tail light set me back $120
'86 SWB SIERRA 1.6EFI, '84 LWB SIERRA 1.0LTR
Post Posted: Wed Aug 01, 2012 7:04 pm
Recovery points
Post Posted: Wed Aug 01, 2012 8:11 pm
as long as your not using the towball... like this bloke (i think from queensland), assuming his 2.5T towbar was up to the recovery
Post Posted: Wed Aug 01, 2012 10:48 pm
alanbie wrote:
Recovery points
Groovy!, did you make them up or can you buy them somewhere?
Orange LWB Sierra
Post Posted: Thu Aug 02, 2012 11:54 am
I dont get how a towball thats that thick can snap off yet a recovery point held by two m10s is fine.. Is it because of the leverage put on it?
Ill post a pic this arvo of how i use my towball for recoveries lol
Vehicle: ***
Post Posted: Thu Aug 02, 2012 12:25 pm
Towball is for "TOWING" it's not called a snatch ball.
Same reason they have "Tow" ropes and "snatch straps"
But then again I've towed a patrol out with my towball so I'm probably not the best person to be telling do's and dont's
Post Posted: Thu Aug 02, 2012 2:43 pm
Jazzor wrote:
alanbie wrote:
Recovery points
I got them laser cut out of 10 or 12PL mild steel, can't remember which, just painted them red after that. The rear bolts on where the original point is and the front slides in between the chassis rail. I've snatced a few lighter vehicles with the rears and have only been towed with the front, the weak point is always going to be the sierra chassis itself which will fail long before a recovery point or a M10 bolt will.
Vehicle: ***
Post Posted: Thu Aug 02, 2012 3:17 pm
What's the rules in other states?
In Western Australia, You're not suppose to have anything protuding out from the vehicle that can cause damage.
ie fishing rod holders must be inside the bullbar. wondering if it would be the same with recover points?
Post Posted: Thu Aug 02, 2012 5:35 pm
is a standard recovery point on the rear on a 92 sierra soft top? i cant seem to see one?
Post Posted: Thu Aug 02, 2012 6:55 pm
Nope :/ There are some good ideas above though!!
Orange LWB Sierra
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Aug 03, 2012 4:13 pm
funnyest thing for the day rotflmao
Green? greeeen is nice !
Post Posted: Fri Aug 03, 2012 4:54 pm
wouldn't be funny when it's embedded into your scull, to who ever said they use their towball for recoveries...
go kick yourself in the dick, repeatedly.
Post Posted: Sat Aug 04, 2012 4:29 pm
me and my mates had a close call the other week with dodgy recovery points cant say how important it is to attach this stuff properly my mate did a light snatch for a guy we found stuck with a car full of kids in the mud at glasshouse we tried doing the right thing and it almost cost my mate is back window and maybe more please bolt through the chassis not just into captive nuts into it they will just rip out
Post Posted: Sun Aug 05, 2012 6:29 pm
mate of mine got told unless he's using the fishing rod holders it has to be inside the bullbar... but if the rods are there, its ok. work that one out :?
:lol: :lol:
Post Posted: Tue Aug 14, 2012 4:48 pm
:lol: :lol:
I don't think their legal at all. But I could see how the rods in would help. The reason they don't like rod holders on the front of your bar is all for the stupid pedestrian. Imagine going over the bonnet and clipping 4 empty holes. Basically turns into a cheese grater..........
Users browsing this forum: No registered users and 12 guests
