It is currently Sat Nov 14, 2026 12:35 pm
Vehicle: 1.3 Tin Top
Post Posted: Sun Sep 09, 2012 9:34 am
Started fabbing up my new winch bar last night. unfortunately i didnt have my camera so i could only take photo's today.
Pretty similar to LTM21's design but i will have 3 tubes on each wing (at this stage) and a hoop over the top to mount lights.
Post Posted: Sun Sep 09, 2012 6:53 pm
:D
Just make sure you drill some holes near the front of the winch plate for water to drain out of.
SS
Post Posted: Sun Sep 09, 2012 7:12 pm
wont the open back be good for drainage? its not sitting right in the photos. it sits pretty flat when in place properly
Post Posted: Mon Sep 10, 2012 2:37 pm
looks good mate, wish id put a taper on the front of my winch cradle, but i wanted to be able to use the high lift on it
Post Posted: Mon Sep 10, 2012 8:12 pm
Fucked up pretty bad today. Drilled both the holes about 1-2mm out so have to drill them larger to fit. not happy but should still be ok. to make matters worse i snapped a brand now drill bit
Vehicle: 1995 Vitara JX
Post Posted: Tue Sep 11, 2012 8:58 am
Looking good, thats the same welder i was thinking of getting!
Post Posted: Tue Sep 11, 2012 9:24 am
Drill the holes out, bolt it up with some nice fat crush plates or washers with the right 10/12mm hole and weld them in place? Not the sort of application you want any slop!
Looks good and solid otherwise - weigh a bit?
Post Posted: Tue Sep 11, 2012 4:11 pm
I drilled them out to 11mm so there is bugger all slop atm. i will probably do as u suggested and weld the washers on though for piece of mind.
Yeah it is heavy but once ive got the tube wings on ill cut away some of the unnecessary plate like on the side plates above the winch plate and on the winch plate itself.
Using pretty light gauge pipe for the wings so overall it should not be too heavy, maybe 20kgs
Post Posted: Tue Sep 11, 2012 4:13 pm
