It is currently Sat Nov 14, 2026 3:42 pm
Post Posted: Thu Dec 04, 2008 2:55 am
I needed a power steer pump for the zook but and I got hold of a std A/C pump and bracket so I decided to make a set up out of the 2 I welded a piece of 10mm flat bar to the a/c bracket which I bent in the press to suit then I got a EA falcon power steer pump and made a bracket to hold it the end result
 Profile YIM
Post Posted: Fri Dec 05, 2008 2:37 am
the finished product
 Profile YIM
Post Posted: Fri Dec 05, 2008 4:14 pm
wow good work mate i wish i had the skills to do that stuff.. it looks sturdy as!
Post Posted: Thu Dec 11, 2008 11:50 pm
thanks I still might have to put a tensioner in there to give it more wrap on the a/c pully
 Profile YIM
Post Posted: Fri Jan 02, 2009 3:48 am
110-120 degrees of belt wrap on the pulley is usually the minimum recommended.
The more the better obviously but see how you go.
Jas.
Users browsing this forum: No registered users and 12 guests
