| compressor cover http://auszookers.com/forum/viewtopic.php?f=14&t=3878 |
| Author: | jamienoble [ Wed Jan 21, 2009 2:35 am ] |
| Post subject: | compressor cover |
i figured this may help prevent some of the water and mud that is prone to getting into the compressor.. has any one else made anything like this?? it is only the prototype.. |
| Author: | just_cruizin [ Wed Jan 21, 2009 2:40 am ] |
| Post subject: | Re: compressor cover |
Take it off or you will kill the compressor, one it blocks air flow to the inlet of the compressor and two have you felt the temperature these things get to, bloody hot, they need air flow around the compressor to cool it. That's why it's got cooling fins. |
| Author: | hooki [ Wed Jan 21, 2009 9:43 am ] |
'just_cruizin' he doesnt have airlockers ( for now |
| Author: | jamienoble [ Thu Jan 22, 2009 2:14 am ] |
yeah it only goes on the compressor when not in use therefore it doesnt block any airflow at all?? as 'hooki' said it is just two velcro straps holding it on.. was just an idea and so far as you can see the compressor is still rather tidy?? i have had it for about 3 months.. never cleaned but regularly used.. i didnt think this would be detrimental to it?? |
| Author: | Damo [ Thu Jan 22, 2009 3:21 am ] |
jamienoble wrote: yeah it only goes on the compressor when not in use therefore it doesnt block any airflow at all?? as 'hooki' said it is just two velcro straps holding it on.. was just an idea and so far as you can see the compressor is still rather tidy?? i have had it for about 3 months.. never cleaned but regularly used.. i didnt think this would be detrimental to it??
As you say, just take the cover off when you're using it. Too easy. |
| Author: | Scrawny [ Fri Jan 23, 2009 3:48 pm ] |
That's a tidy little cover. Did you make it Jamie? Good job
| Author: | just_cruizin [ Fri Jan 23, 2009 6:33 pm ] |
How noisey are these new one compared to the old style, thinking about mounting mine in the cab. |
| Author: | kenn [ Fri Jan 23, 2009 11:49 pm ] |
An analogy : 50's VW vs 2008 Golf.. |
| Author: | jamienoble [ Sat Jan 24, 2009 7:46 am ] |
cheers scrawnc! i cut it all up and figured out approx the sizing and then one of my mates has a heavy duty sowing machine so he sowed it for me!! but as i say there are defs some improvements in need.. and for the noise factor, this is the first one i have owned but i know alot of people who have mounted them in cab behind seats etc and have not complained but overall a wicked compressor, highly recommend! |
| Author: | brendan [ Fri Jan 30, 2009 1:31 am ] |
i got a compressor mount inside the car on the drives said rear wheel arch |
| Author: | just_cruizin [ Fri Jan 30, 2009 3:53 am ] |
brendan wrote: i got a compressor mount inside the car on the drives said rear wheel arch
and ....... a) it's fine, not noisey at all and I barely notice when it cuts in b) I nearly crap myself everytime and it shits me to tears. |
| Author: | brendan [ Fri Jan 30, 2009 4:14 am ] |
i was just saying. yes it noise yes you would more then likely shit yourself if your not expecting it but i dont have air lockers so its left off. it main purpose is for pumping up tires and i left off untill it time to air up. |
