It is currently Mon Nov 02, 2026 10:33 pm
Vehicle: 98 jimny
Post Posted: Mon Apr 22, 2013 2:50 pm
Since I'm starting to pull things off the jimny and things and have set m self up a under cover work space thought to my self, what does all good work shops need? And what do I have laying around to make it from?
The answer was a parts wash down station.
All up it cost me $2 because the tub I had was a little too small,
So I found a good size one at bunnings.
Now I'm not designing one to wash a whole axle just the little things that get greasy.
Now for the build
This is what I started with
*A bucket/container
*a window washer motor out of my charade
*A switch
*A power supply
I screwed the window washer bottle to the bucket and drilled a hole just below half way so I won't be sucking In all the dirt and chunky bits from washing dirty things
Then I mounted the squirter thing to the side of the bucket and pointed them down
Then I mounted a switch to turn the motor on/off
Action shot :woohoo:
Now I'm just siliconing everything up and waterproofing all the electrics
Post Posted: Mon Apr 22, 2013 5:09 pm
Nice, keep us updated with how well the motor lasts
Vehicle: 98 jimny
Post Posted: Mon Apr 22, 2013 5:20 pm
Should last a while running 7.7 volts into it and all it is is a brushless motor spinning a propeller thing that forces the water/degreaser down the tube thinking tho I should add a little bit of mesh over the intake hole
Post Posted: Mon Apr 22, 2013 5:23 pm
I should have said pump/propeller not motor haha, I generally use CT14 which is pretty harsh and was wondering how the plastic parts would handle it
Vehicle: 98 jimny
Post Posted: Mon Apr 22, 2013 6:57 pm
I was thinking about getting some of this Eco stuff we used on the drill rigs, harsh on grease but was safe to leave in a plastic squirter bottle
And smells minty :wink:
Post Posted: Mon Apr 22, 2013 7:39 pm
should have bought an old dishwasher.....
Vehicle: 98 jimny
Post Posted: Mon Apr 22, 2013 8:37 pm
Lol doubt it would of cost $2 lol
Post Posted: Mon Apr 22, 2013 8:40 pm
what happened to using your brothers/wife/gf's toothbrush?
Vehicle: 98 jimny
Post Posted: Mon Apr 22, 2013 8:43 pm
Lol wouldn't have one for long if I did that lol
Post Posted: Tue Apr 23, 2013 7:11 am
couldn't you have taken the pump off the bottle and attached that directly to the tub?
Vehicle: 98 jimny
Post Posted: Tue Apr 23, 2013 11:04 am
2 reasons I didn't.
* having a separate tank with a small hole half way up the tub filters all the heavy particals that fall off what your cleaning
* the tank is formed around the motor and with it having the impeller thing it wouldn't work just putting it in the side of the tub
Post Posted: Wed Apr 24, 2013 5:02 pm
What's wrong with just using the dishwasher?
Post Posted: Thu Apr 25, 2013 8:49 pm
leaves a film on the glasses in the same load
Post Posted: Fri Apr 26, 2013 7:25 am
awsome idea mate, the only thing that I would change is get rid of the washer jets and just have the 4mm dia hose spraying out the cleaner. The parts washer I use at work has a beast jet on it and its a pain in the cunce for rinsing shit off it just splatters everywhere.
Instead of the washer just just use a paint brush to scrub the grease off and then the pump is just washing the last bits of shit off.
Just my 2c worth. Other then that tops idea!
Dave
Post Posted: Fri Apr 26, 2013 12:14 pm
cool idea dude!
just be careful with what you use in it. most parts cleaners are metal for a reason. also, they have a "fuseable link" kind of thing in the lid hinge (another thing you dont have) In case whatever is in there catches fire, the hinge will shear and lid will slam shut...
so either dont use any flammable degreaser in there (good luck) or be really really careful what you do and where you do it. and maybe have a fire blanket handy. would hate to see it catch fire, the bucket melt, and have you standing around with a nice pool of flames going everywhere (hate to think if pump was still going too! instant flame thrower!)
oh and most of the switches are sealed to prevent sparks.
awesome idea though! be careful!
EDIT:
not to rain on your parade, but you can get proper ones for quite cheap on ebay.
http://www.ebay.com.au/itm/BRAND-NEW-3- ... d11&_uhb=1
MY BUILD THREAD HERE!!!!!
Post Posted: Sun Apr 28, 2013 9:08 am
You can buy pretty good non-flammable non-irritant parts cleaner. We use it at work now, seems four 44gal drums full of flammable cleaners lying around the workshop wasn't a good idea. Problem with the non-flammable cleaner is it needs to be heated to work the best.
Users browsing this forum: No registered users and 25 guests
