[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
ozz53
Vehicle: 92 Sierra
 Posted: Wed May 07, 2014 6:48 am |
Ok so this is what i have so far and just wanted to see what everyone thinks. I haven't got access to a bender that will bend tight bends so im making sure everything is sweet before i send off a template to get bent up. after I did this im starting to think that i should have put it up higher maybe even cut the front grill and mounted it ( to improve the angle). The winch is over kill but i got it for the same price as a 9000lbs so i went the big one, anyway do you think i should mount this higher or it wont be a problem? cheers
pezz
Joined: Fri May 15, 2009 11:30 pm Posts: 2108 Location: western vic
Vehicle: sj51
 Posted: Wed May 07, 2014 8:48 pm |
i have mine in a similar location, mine sticks out just as far, i rarely hit the bar before the shackles
ozz53
Vehicle: 92 Sierra
 Posted: Thu May 08, 2014 6:38 am |
Thx for reply Pezz, it was playing on my mind for the last couple of days. Ill take it out this weekend and give it a run as it is aswell, one other question i didnt ask is what size bar work are most people using? I was going to use 34 ish ID to give me a 40mm OD but I did get told this might be overkill, one day i might continue the bar work down the side to sliders so 3mm wall would be needed in my mind but i deal with electricity not steel so advice on this would be appreciated.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu May 08, 2014 4:13 pm |
The material sounds fine. The leading point is lower than i would build myself. But if you don't go any lower/further forward with the tube it should be sweet. Then get bigger tyres!
_________________ mlm
ozz53
Vehicle: 92 Sierra
 Posted: Fri May 09, 2014 5:59 pm |
Thx for reply man, tube work defiantly want be going any lower or forward. Bigger tires are an option but ill wait until these are buggered.
[ 5 posts ] |
Users browsing this forum: No registered users and 10 guests
