It is currently Sat Nov 14, 2026 6:12 am
Vehicle: Vitara 1997
Post Posted: Sun Jul 07, 2013 12:46 pm
I recently bought myself a pipe bender and had a go at making a front bar. Thoughts? things I could think about before making a rear bar and sliders?
Post Posted: Sun Jul 07, 2013 12:52 pm
Looks alright. Have you got photos of the mounts? How is it attached to the chassis?
Post Posted: Sun Jul 07, 2013 12:58 pm
ill have to go take some.. I welded tabs on so it bolts onto the existing bumper mounts and then made brackets up so it also bolts onto the nudge bar mounting points I had. figured it should be plenty strong enough as im not winching off it
Post Posted: Sun Jul 07, 2013 1:42 pm
I'm just toying with ideas of building my own
Post Posted: Sun Jul 07, 2013 2:12 pm
Nice:) it only cost like $50! Ill try get some photos of the mounts. If you can weld and have access to a bender give it ago
Post Posted: Sun Jul 07, 2013 4:05 pm
Looks pretty good mate, nice and simple.
Hard to tell from the photos but are the outside corners collapsed a bit? What bender and what dies are you using?
Have a look at some of the other Vit threads for some mounting ideas - most of us whack an additional M12 or two through the nubs at the front:
Vehicle: Sierra LWB, SWB t/top
Post Posted: Sun Jul 07, 2013 6:54 pm
Are your bends actually crushed?
Post Posted: Sun Jul 07, 2013 8:54 pm
Nice simple design, And well executed, but I'd have another go at the top bar if I were you. Those bends are completely collapsed, and will offer very little protection without bending further.
Post Posted: Mon Jul 08, 2013 5:50 pm
Yeh the corner bends are a bit crushed. Ill have to work out how to make work better. One idea I've been given are filling the pipe with sand.. Anyone tried this? I'm just using a cheap 12T press bender. It's 2inch pipe about 3mm thick.
Post Posted: Mon Jul 08, 2013 5:51 pm
i've heard sand is the go too
Post Posted: Mon Jul 08, 2013 6:14 pm
U can do more of a sweeping bend by doing a few bends 50mm apart
Post Posted: Mon Jul 08, 2013 9:36 pm
The problem is the die. They are a poor fit. Buy yourself a quality Dawn die for your bender.
Vehicle: Black '96 X-90
Post Posted: Wed Jul 10, 2013 12:04 am
The design looks great to me. And really simple too. I like it!
Post Posted: Wed Jul 10, 2013 12:11 pm
Looks good, Sand still won't work right
Post Posted: Wed Jul 10, 2013 10:23 pm
Thanks guys. So filling it with sand won't work! I'd imagine it would be very hard to force the bend.. I looking into making a 2inch exhaust so it would be good to get the bender working well. Should be able to get away with more sweeping bends for that though I hope. Still haven't had a chance to get some photos of the way I mounted it. Works been crazy
Vehicle: 92 vitara 3 door
Post Posted: Thu Jul 11, 2013 5:17 am
Hey bud I used sand and annealed my pipe before bending on the press bend worked not to bad if u wanna give that a crack
Vehicle: SWB Sierra
Post Posted: Thu Jul 11, 2013 6:38 pm
This
Post Posted: Thu Jul 11, 2013 6:45 pm
cool might try that
Post Posted: Thu Jul 11, 2013 6:48 pm
here are some pics of the way I mounted the bar
Users browsing this forum: No registered users and 21 guests
