It is currently Tue Oct 20, 2026 12:31 am
Vehicle: 2013 jimny
Post Posted: Mon Jul 07, 2014 9:28 am
Since I don't really want to remove my rear seats, I knocked up a small boot platform over the weekend to make the boot space flatter and give a little bit of space under it to store small, loose items.
I used the 25.4mm Connect-it aluminium with plastic connectors from bunnings and 4mm thick aluminium composite cladding. I put some felt on either end to hopefully stop more scratches on the plastic and I plan to cover the composite sheeting with some rubber matting.
Vehicle: Suzuki Jimny
Post Posted: Mon Jul 07, 2014 11:04 am
how did you remove the bottom of the rear seat??
Vehicle: 2013 jimny
Post Posted: Mon Jul 07, 2014 12:54 pm
Jim, I haven't removed any part of the rear seats, just folded them forward.
But from memory, I think you can just pull up each corner of the seat cushion and it un clips.
Vehicle: 2013 jimny
Post Posted: Fri Jul 18, 2014 2:07 pm
This is where i got the idea from for this.
Vehicle: 2000 Jimny
Post Posted: Sat Jul 19, 2014 5:55 pm
i can see myself making one of these, good job.
Vehicle: 2013 jimny
Post Posted: Tue Jul 22, 2014 2:54 pm
Cheers mate. Its quite hand for stashing small bits and pieces under, maybe recovery gear or tools etc.
I think that Japanese one was around $180 excluding delivery costs. Mine was about $50 all up, but you could probably do it for less.
Post Posted: Thu Jul 24, 2014 8:56 pm
Good idea, might do this too. Did you attach it to the boot anywhere to stop it bouncing around or does it stay pretty stable?
Vehicle: 2013 jimny
Post Posted: Sat Jul 26, 2014 2:39 pm
I didn't attach it to the car anywhere, it might be ok just sitting there, but I have my fridge tied down on top of it so it can't go anywhere.
The blue blanket is just a throw rug thing that I use for a sort of drop sheet to cover the back seats and keep the back clean when I'm chucking dirty or sandy gear in the back.
Users browsing this forum: No registered users and 31 guests
