| Jimny Boot Platform http://auszookers.com/forum/viewtopic.php?f=14&t=46878 |
| Author: | Ridin [ Mon Jul 07, 2014 9:28 am ] |
| Post subject: | Jimny Boot Platform |
Since I don't really want to remove my rear seats, I knocked up a small boot platform over the weekend to make the boot space flatter and give a little bit of space under it to store small, loose items. I used the 25.4mm Connect-it aluminium with plastic connectors from bunnings and 4mm thick aluminium composite cladding. I put some felt on either end to hopefully stop more scratches on the plastic and I plan to cover the composite sheeting with some rubber matting. |
| Author: | Jim_Aus [ Mon Jul 07, 2014 11:04 am ] |
| Post subject: | Re: Jimny Boot Platform |
how did you remove the bottom of the rear seat?? |
| Author: | Ridin [ Mon Jul 07, 2014 12:54 pm ] |
Jim_Aus wrote: how did you remove the bottom of the rear seat?? Jim, I haven't removed any part of the rear seats, just folded them forward. But from memory, I think you can just pull up each corner of the seat cushion and it un clips. |
| Author: | Ridin [ Fri Jul 18, 2014 2:07 pm ] |
This is where i got the idea from for this. |
| Author: | GraphicX [ Sat Jul 19, 2014 5:55 pm ] |
i can see myself making one of these, good job. |
| Author: | Ridin [ Tue Jul 22, 2014 2:54 pm ] |
GraphicX wrote: i can see myself making one of these, good job. Cheers mate. Its quite hand for stashing small bits and pieces under, maybe recovery gear or tools etc. I think that Japanese one was around $180 excluding delivery costs. Mine was about $50 all up, but you could probably do it for less. |
| Author: | Danbo [ Thu Jul 24, 2014 8:56 pm ] |
Good idea, might do this too. Did you attach it to the boot anywhere to stop it bouncing around or does it stay pretty stable? |
| Author: | Ridin [ Sat Jul 26, 2014 2:39 pm ] |
Danbo wrote: Good idea, might do this too. Did you attach it to the boot anywhere to stop it bouncing around or does it stay pretty stable? I didn't attach it to the car anywhere, it might be ok just sitting there, but I have my fridge tied down on top of it so it can't go anywhere. The blue blanket is just a throw rug thing that I use for a sort of drop sheet to cover the back seats and keep the back clean when I'm chucking dirty or sandy gear in the back. |
