It is currently Tue Oct 20, 2026 12:32 am
Vehicle: 2004GV + bar + custom mods
Post Posted: Fri Aug 01, 2014 8:31 am
Just a dump of photos of my UNIFINISHED project (was stolen 2 days ago. rebuild pending)
Initial CAD
New toy - stick inverter
Chassis clamps
First rough assembly after bending - did not use sand, bend went wrong. Use sand, it helps a lot.
What it would look like really
Notching setup. Too much vibration, kills the saw prematurely, but it works for cheap. Jig allows 45 degree cuts
Global view
Cozy bending, packed with sand. Great results.
Bender mod to bend back my enthusiasm
Last photo of it before it was stolen
Well obviously it was not finished, and am pissed off I was robbed. But I'll do it again. I have the whole CAD and concept proven by now (not track tested)
Next time I will buy steel, and not re-use discarded galvanized pipes, cause they are crap to weld (even ground) and the remaining galva is poisonous.
Also if you come around someone with these sliders (they have M marked steel and one of the sliders has no front element welded) make sure to say hi for me.
Full album: http://imgur.com/a/dh6tk
Vehicle: Which one?
Post Posted: Fri Aug 01, 2014 8:34 am
What the actual fuck? Some jerk-off stole some unfinished sliders? These are pretty unique and there aren't too many GVs around with sliders so who knows what they'd do with them.
Where were they nicked from?
Post Posted: Fri Aug 01, 2014 8:41 am
nicked from my park spot down my building. Access card required to get there. We had multiple incidents over the years.
Unfinished and rough as - the photos do a good job hiding my shit welds.
I guess with a bit of work you could use them for any 4wd but it wouldn't fit well, they are 160 long, very GV specific.
So, yeah, very frustrated.
Will have to re-do it all, this time with proper steal [EDIT] Steel - aha.
If anyone can direct me to a good supplier around Brissy, I'll get going.
I need about 5 meters of 4mm thick 35mm diameter pipe. And 2 meters 5mmx40mm bar. Maybe some checker and stuff.
I ain't given up. too pissed off for that.
Vehicle: Which one?
Post Posted: Fri Aug 01, 2014 8:45 am
No CCTV for your building?
Vehicle: 91 Tin Top
Post Posted: Fri Aug 01, 2014 8:49 am
Well that's got to be a new low.... Grubs!
Keep an eye out for roof racks too, they might not work as sliders for other cars but can see how someone might think they would look good as sides on a flat roof rack.
Post Posted: Fri Aug 01, 2014 9:20 am
no cctv. YET. maybe. years of discussions. Time to move out altogether. Get myself a shed with electrical fence, moats and some frikkin turrets.
Pete, these are steel, heavy bastards. you'd have to be mad to put that on your roof. Then again, whoever stole em is probably not the brightest.
Post Posted: Fri Aug 01, 2014 12:09 pm
That's shit mate, I'd put money on it being drug dependent turds using it for scrap.
Vehicle: suzuki Grand Vitara
Post Posted: Fri Aug 01, 2014 7:36 pm
If these work well would you consider fabricating more to sell?
Post Posted: Fri Aug 01, 2014 11:31 pm
I make and sell rails if that is easier......
Post Posted: Sun Aug 03, 2014 8:09 am
Do these work as sliders too tho?
Post Posted: Sun Aug 03, 2014 9:36 pm
Yep they are made from 40NB Australian Pipe with 3.2mm wall thickness. Mounted right you can use them as a highlift location
Post Posted: Mon Aug 04, 2014 9:12 am
jtraf, coincidentally just found yours on gumtree/ebay while looking for my missing ones.
Designing and building them is half the fun, with learning the howto techniques etc. - Mine were (and will be again) 33.7NB 3.2 Gauge.
Curious to know what you use for notching though ? clearly you have some experience making these.
Post Posted: Mon Aug 04, 2014 1:29 pm
JD2 Notcher with Bi-Metal Holesaws for notching.
There are cheaper ones on the market that may suit your needs though.
Post Posted: Mon Aug 04, 2014 2:11 pm
http://jd2.com.au/notchers/tn-100.html clearly over my budget :D But I'll keep that in mind in case I need more fab done. I'll stick to my very DIY setup for now.
Am about to buy some steel with some bits pre-cut so hopefully I just have to bend, notch and weld. I want to see this thing DONE.
Users browsing this forum: No registered users and 31 guests
