It is currently Mon Oct 19, 2026 9:38 pm
Vehicle: Vitara 1997
Post Posted: Fri Aug 22, 2014 5:17 pm
Started making a rear bar last weekend. Pretty happy with how its looking. I guess I should put some mudflaps on? I really dont like the look of them though. Also going to weld on some recovery points and a bit of black checkerplate on the top to cover up that gap and make a step..
Post Posted: Sun Aug 24, 2014 6:14 pm
Considering that not having mudflaps would be the #1 reason cars get defected I'd be putting them on.
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Aug 24, 2014 6:21 pm
I am not that comfortable with recovery points that are welded on.
Post Posted: Mon Aug 25, 2014 4:39 pm
yeh ive bought some mudflaps.. dont need to draw attention to the other parts of my car they could defect if they wanted.
I was thinking of making kind of t shaped recovery points, so i could have the t section behind the bar and then the longer bit sticking though with a hole for a shackle. That way im not just relying on one weld. It kinda scares me too.
Post Posted: Fri Sep 19, 2014 8:23 am
I thought i might update this, the bar is all finished now, mudflaps (not heaps happy with where they sit yet) checker plate and number plate lights. Admittedly it cost a bit more then $60 now but the checker plate was free :)
Vehicle: 2002 Suzuki Grand Vitara wide
Post Posted: Sun Sep 21, 2014 7:24 am
Nice work, Nick.
Looks tough.
Post Posted: Sun Sep 21, 2014 8:55 am
Thanks mate, im super happy with it now
Post Posted: Sun Sep 21, 2014 9:10 am
How did you bend your pipes?
Post Posted: Sun Sep 21, 2014 9:54 am
Ive just got a cheep hydraulic press bender. Working on making a proper mandrel bender though which should give some better results
Vehicle: 1994 sierra
Post Posted: Sat Oct 11, 2014 7:10 pm
nice work. i need one of these
Vehicle: 1997 suzuki vitara jx 4dr
Post Posted: Mon Oct 13, 2014 5:29 pm
Hey mate would you consider making one for a lwd 97 vitara winch compatible
Post Posted: Mon Oct 13, 2014 5:59 pm
you need a rear mounted winch, for what? :?
Post Posted: Mon Oct 13, 2014 8:38 pm
Hey, just got engaged so wont have time to make anything before the end of the yr. If one or two people are seriously interested i might consider it next yr... Dont really know how the winch idea would go though, i guess it would be strong enough, i attached it to the tow bar mounts but not sure if there would be enough room behind it for the winch.. might have to make the whole bar stick out more to fit it in
Vehicle: Lwb vit, 31's big white fridge
Post Posted: Wed Nov 26, 2014 9:22 pm
Recovery points are to be bolted on only. Never use shackles in snatch recovery
Post Posted: Fri Nov 28, 2014 8:13 am
Rear winches are the new "in thing"
Post Posted: Fri Nov 28, 2014 8:19 am
You're not serious right? Of course shackles can be used in a snatch recovery.
Post Posted: Tue Dec 02, 2014 8:21 pm
Ever seen one impaled in the back of someones head?
I've been lucky and just seen it go through a door.
Post Posted: Tue Dec 02, 2014 8:26 pm
how do you attach a snatch strap to something like a towbar with the ball removed, skyhooks?
hell, even the rated billet machined receiver hitches that slide into a hayman reese towbar have shackles to attach the strap to the vehicle.
Post Posted: Tue Dec 02, 2014 9:42 pm
Hell they use shackles in industry. As long as its rated it isnt a problem
Post Posted: Wed Dec 03, 2014 12:18 am
joining a strap with one definitely is.
i'd be worried if you've got substandard recovery points or the hillbilly factor takes over & the recovery goes redneck. :wink:
Post Posted: Wed Dec 03, 2014 7:38 am
No but I also haven't used one that wasn't rated for the job it was doing. Unless you've got a hayman reese towbar that you use the pin through the eye of the strap or you've got a hook with a safety catch you need to use a shackle.
Post Posted: Thu Dec 04, 2014 4:58 pm
When the consequence is death, why wouldn't you spend the couple hundred to get recovery hooks fitted properly?
Shackles are only rated to a straight line pull, and not for twisting either... How many recovery's end up involving both?
Post Posted: Sat Dec 06, 2014 2:12 pm
Bow shackles are good for off-axis loads... but only in one direction.
In the cases where shackles have gone flying, how often is the shackle itself the point of failure (assuming an adequately rated bow shackle is used.)
Vehicle: 91 and 97 grand vitaras
Post Posted: Sat Jan 31, 2015 9:27 pm
Nice job on the bar I did notice the kinks from the press bender they really aren't much chop.next time try filling the tube with sand and tax some caps on it and it should bend better.
And on the topping of welded recovery points 1 inch of good penetrated weld is capable of lifting a tonne so if it's welded fully it should withstand anything I have them on mine and have recovery many a snatch without fail or hint off.
Post Posted: Tue Feb 03, 2015 3:42 pm
Yeh ive gone one step further and have a laser cut kit for a proper mandrel bender waiting to be assembled. I just got to but the bullet and buy a $500 die for it but that should get me flawless results :) But ive pretty much made all the bar work i need on my zook already! haha
mmm i do still need to do the recovery points.. and i will have to weld something cause there is no where to bolt anything on with this custom bar
Vehicle: Suzuki Vitara SWB 1992
Post Posted: Sat Oct 01, 2016 10:45 pm
those mudflaps are in adequate can only be a maximum of 240 mm off the ground to the bottom of the mud flaps, awesome build tho
Vehicle: 98 Suzuki Vitara
Post Posted: Sun Nov 09, 2025 10:08 pm
How did U mount the bar
Post Posted: Mon Nov 10, 2025 9:42 am
Holy gravedig Batman!
The OP hasn’t been on here for 10 years so I don’t imagine you’re going to get an answer.
