It is currently Wed Oct 28, 2026 4:58 am
Post Posted: Mon Aug 25, 2014 2:28 pm
Ok so a mate and i did this the other day, we read quite a few things that were wrong about this conversion so this is required
Things needed..
Mg410 4 speed box
1300 sierra 5 speed
tools and a press (may not need press but made life easy)
how to do it
Pull both extension housings off and separate both gearbox's
pull both gear sets out (may need press)
then put the 1ltr input shaft onto the 1300 gear set and put the gear set back into the 1ltr housing.
then punch the roll pins out of the selector forks in the 1ltr gearbox, slide them out (mind the detent balls) and put them aside. do the same for the 1300 rails.
then put the 1300 rails into the 1ltr housings, be mindful to get them back right and get the detent balls back in.
put the top back on the gearbox, be mindful to line up the shifter forks with the selector rings in the box, then put the 1300 extention housing on, place a shifter in and see if you have all your gears and it shifts!
if it works, pull box back apart, add silicon, bolt back up and your done.
Note..
this gives you better ratio's and a 5 speed
you need to use the 1300 extension housing as the rails are longer and there is no prevision for the 5th gear bearing in the 1ltr housing
Hopefully this helps.
Post Posted: Tue Aug 26, 2014 11:19 pm
How do you find the fifth gear ? Does the 1 litre handle it ok ?
Post Posted: Fri Sep 26, 2014 9:04 am
i dont use it much as im running 34's but the first is defiantly much lower, and thats what i was trying to achieve
Post Posted: Sat Jan 03, 2015 10:53 pm
How is the 5 speed conversion going? Do you know if this will fit in the LJ80? Do you have any pics you could share with us?
Thanks for any help
Cheers Jamie
Post Posted: Sat Jan 03, 2015 11:23 pm
The gearbox fits in the tunnel but you'l have to chop out the trans crossmember and make a new one. Also need to chop a hole in the floor for the shifter and get a custom length jackshaft made.
Post Posted: Tue Jan 06, 2015 11:04 pm
Are the MG410 4 speed box's easy to find to do this conversion?
Thanks for any help.
Cheers Jamie
Post Posted: Tue Jan 06, 2015 11:25 pm
They're quite rare. It took me years to find one, that's partially because I live in the middle of nowhere though.
Post Posted: Wed Jan 07, 2015 9:47 am
Cheers Jamie
I have 2 of them! One running in snotbox with the 5 speed conversion. and the other sitting in the shed next to a 1.3 donor box waiting to be rebuilt as a spare. Let me know if your after one :wink:
Post Posted: Wed Jan 07, 2015 10:45 am
Does anyone know why we need to use the mg410 4 speed and not say the lj80 4 speed to do the conversion?
Cheers Jamie
Post Posted: Wed Jan 07, 2015 11:13 am
your kidding right? why not try the gearbox from a baleno instead?
Post Posted: Wed Jan 07, 2015 11:21 am
Because different.
Post Posted: Wed Jan 07, 2015 11:26 am
The MG410 gearbox (you can also use the gearbox from a type 3 1l, but that's the rarest sierra around) is essentially the same as the 1.3l 5 speed gearbox, but with a different bellhousing pattern and a 4 speed gearset.
The LJ gearbox is totally different in every way, it's much smaller too.
Post Posted: Wed Jan 07, 2015 12:31 pm
Thanks for the info that's all I needed to know.
cheers Jamie
Vehicle: 93maruti
Post Posted: Sun May 03, 2015 9:01 pm
Are you running transfer gears as well? I've got the two boxes sitting here doing nothing, but I'm about to put 6.5:1 gears in. Just wondering how low that 1st will be then and if it would in turn make 5th usable. Diffs are 4.1:1 and tyres are 31.
Vehicle: MG410 WT
Post Posted: Tue May 26, 2015 9:04 am
Are the 1l sj410 gearbox's same as mg410's?
Vehicle: sj40
Post Posted: Mon Aug 31, 2015 6:50 pm
This may be a silly question but are the 1l sj410 gearbox's same as mg410's?
Post Posted: Fri Sep 04, 2015 11:15 am
Only the type 3 sj410's. These are cars with the plastic NT1.3 type dashboard.
Post Posted: Sun Sep 13, 2015 6:34 pm
Is the output spline that comes out of gear box the same on the two cars or do you have to get a 1300 output shaft?
Post Posted: Sun Sep 13, 2015 8:22 pm
Not 100% sure.
Mine was a mg410 so it fit straight up.
Im about to pull this box out to make way for a 1.6 if anyone is looking for one.
Post Posted: Sun Sep 20, 2015 10:24 pm
Done this mod over the weekend just waiting for my front and rear seals to rock up and put the box back in.
Post Posted: Sun Jan 01, 2017 6:22 am
Any pic's of all this??
Users browsing this forum: No registered users and 13 guests
