| wt vert lift flares http://auszookers.com/forum/viewtopic.php?f=14&t=48273 |
| Author: | pezz [ Wed Oct 29, 2014 1:22 pm ] |
| Post subject: | wt vert lift flares |
Problem: Stock wide track flare is to short for vert lift opening ![]() Solution: added 70mm of another flare into the center of it
| Author: | monley [ Wed Oct 29, 2014 8:15 pm ] |
| Post subject: | Re: wt vert lift flares |
Good job Pezz! Would of been a nice fiddley job |
| Author: | greenzook89 [ Thu Oct 30, 2014 5:18 pm ] |
Nice. Any pics of the process? |
| Author: | DMAC [ Fri Oct 31, 2014 7:20 am ] |
I've been waiting for the Pezz fab. Nice solution to keeping things looking stock. |
| Author: | pezz [ Fri Oct 31, 2014 6:02 pm ] |
Thanks guys, ive only done the one for far, will post up some process pic's as I do the other three, will be sculpting the flares to suit the blinkers and fuel filler also. |
| Author: | jono165 [ Fri Oct 31, 2014 9:48 pm ] |
I like it! Definitely one of the better solutions I've seen. It's so hard to get flares that look ok on sierras. |
| Author: | pezz [ Wed Nov 05, 2014 4:51 pm ] |
Front flare done, 60mm extention and cut out to suit blinker
| Author: | prickle [ Wed Nov 05, 2014 5:08 pm ] |
pezz wrote: Front flare done, 60mm extention and cut out to suit blinker ![]() Hi Pezz Any chance of a front on shot ... tyre / flare Stuart ............. Samsung S4 |
| Author: | pezz [ Wed Nov 05, 2014 5:57 pm ] |
Will take one tomorrow, its just a stock width wt flare tho.. |
| Author: | buzbox [ Wed Nov 05, 2014 6:35 pm ] |
Nice work, I was going to do this but call me lazy, It's too much work for little gain. I just tilted it towards the front a bit more.
| Author: | pezz [ Wed Nov 05, 2014 7:52 pm ] |
I recon yours looks neater, with the front endge all the way down and not sitting as high |
| Author: | buzbox [ Wed Nov 05, 2014 8:41 pm ] |
Yours is very seamless and you've done a good job of it, i just took the easier option. |
| Author: | pezz [ Thu Nov 06, 2014 8:41 am ] |
![]() ![]() ![]() flares are yet to be bolted on, they are just stilling on the mounts, still need to make up some inner trims to fill the void between the flare and the body Tyre position will change as I've yet to bolt up my wt diffs, currently 15x8 rim with neg offset, but will be going to a narrower rim with possitive offset to keep it skinny |
