It is currently Tue Oct 20, 2026 12:32 am
Vehicle: Suzuki Sierra Trayback
Post Posted: Tue Nov 04, 2014 3:23 pm
Knocked up a cheap front bar the other day using the design of a fellow auzooker.
Used 50mmx 2mm blue RHS and 40mmx 2mm blue RHS for the bottom corner diagonal braces , mounting brackets and top gusset were fabbed out of 50mmx8mm Flat bar. The finished unit weighs in at 12.7kg and is only 4.5kg heavier than the original unit. The blinkers are the std Suzuki ones and will need changing to something less ugly.
Basically it's going to be used to mount a Light bar/Aerial and maybe fend off a crazed roo. Used a CIG welder and a dozen or so 2.5mm GP welding rods, a flap disc to smooth welds, some plastic plugs to fill the open ends and then painted with black Zinc paint.
Regards Nick.
Vehicle: MG410 WT
Post Posted: Thu Nov 06, 2014 8:46 am
:goodjob:
Vehicle: Sierra
Post Posted: Thu Nov 06, 2014 9:13 pm
Looks sweet as mate great job, any chance you could share the drawing so I can build one?
cheers
Vehicle: 2000 Jimny
Post Posted: Fri Nov 07, 2014 10:32 am
that looks sh!t hot, well done.
Post Posted: Fri Nov 07, 2014 9:42 pm
PM'd you Tonner.
I also used a drop saw to get the cuts half descent. You have the option of using 2.5mm or 3mm RHS if you need more strength, but I went for 2mm.
Nick
Users browsing this forum: No registered users and 31 guests
