It is currently Mon Oct 19, 2026 11:36 pm
Vehicle: 2000 Grand Vitara V6
Post Posted: Tue Feb 10, 2015 7:55 pm
Hey guys, I am new to posting here but thought some might be interested in my 2.5L V6 (H25A) Grand Vitara turbo conversion.
I am currently gathering parts and pulling things down to start the fabrication of the exhaust manifold to mount the turbo and build an exhaust.
I will start putting pics up as I progress, If I should start a thread elsewhere let me know as I am new here.
Cheers! Jordo.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Feb 11, 2015 1:16 pm
you could start a build thread, but it kinda fits here if your fabing your own manifolds and stuff too.
Post Posted: Wed Feb 11, 2015 9:23 pm
Perhaps the build thread might be the go, I am taking photos along the way and it should be fun for anyone interested. Am fabricating manifolds from scratch with help from a mate.
Parts have started arriving today so will start putting something together. Cheers for the advice!
Post Posted: Thu Feb 12, 2015 10:43 pm
Be interesting to see what gains will be had and how reliableo this motor will be. Do you have a Hp goal or just trying to get the most out the motor?
Post Posted: Fri Apr 03, 2015 10:37 am
I think about turboing the mrs grand vitara everytime i stick my head under the bonnet.
Was thinking twin turbos, off of something like a rb26 or 2jz and should be close to the right size. Twin front intercoolers mounted with inlet at the bottom, outlet at the top with two pipe over too two throttle bodies mounted of the exsisting manifold. The engine is begging for the configuration in my mind.
Now I will stop day dreaming and let you do it for real. Look foward too the build.
Vehicle: 04 Grand Vitara, 2.5L, V6
Post Posted: Fri Apr 03, 2015 10:56 am
Thinking would need a body lift just to attempt to fit it in and then a hood scoop to improve cooling
Vehicle: 99 Grand Vitara SQ
Post Posted: Wed May 20, 2015 10:32 pm
Why twin front intercoolers? You can buy an intercooler with twin inlet and one out..
Im thinking of a supercharger.. but forged internals will be a must..
Vehicle: SJ70 1993
Post Posted: Thu May 21, 2015 8:42 am
I got all the info to start a supercharger project on my g16b but waiting on funds before I start.
good luck on the build
Post Posted: Fri May 22, 2015 8:57 pm
Ok guys, I have put together an album of what I have been up to so far on the turbo Grand Vitara project.
It's a bit all over the place but hopefully shows enough of what I have done for now
Check out the link here: http://imgur.com/a/R9Dz9
Let me know if you have any questions!
Post Posted: Sat May 23, 2015 1:59 am
I was impressed with the pipe work & all that... then I got to this.
photoshop level expert! Armsup
Post Posted: Sun May 24, 2015 7:41 am
I had to throw that pic in there ☺️, I have a signage business and this guy was a cutout from an old exhibition. Has made it into many photobombs
Post Posted: Tue May 26, 2015 9:59 am
Nice work! Looks pretty schmick! What turbo are you running and what ecu will you use? Also where did you tap oil feed from?
http://www.strictly4x4.com.au
Post Posted: Sun May 31, 2015 10:41 pm
Thanks! Turbo is Gt28, ECU is Adaptronic e440d - http://www.adaptronic.com.au/product/e440d/
Running an in tank Bosch 040 pump and 540cc injectors. Oil feed was sourced from oil pressure switch on left side of block with a T piece made to run both.
Post Posted: Tue Jun 02, 2015 1:12 am
That may not be the best place - I've had the brass fittings fatigue & break off leaving the stub in the block.
Post Posted: Tue Jun 02, 2015 5:49 pm
Nice, planning on running e85 through it? That's a pretty cheap ECU with features like that.
Vehicle: '96 LWB trayback
Post Posted: Tue Jun 02, 2015 7:43 pm
Be careful running a T-piece sharing your pressure switch and turbo oil feed.
In cars with high levels of vibration it's VERY common for components to fail in this setup. ie: Brass tee fractures resulting in catastrophic oil loss and engine failure.
It used to be all the rage to use this method on MX5's. Failures were so common that during club race days, cars with this method wouldn't pass scrutineering.
Offroad a 4wd would be just as likely to have a rough enough ride to promote failure.
Where are you located Jordo? Who's tuning the Adaptronic for you?
Post Posted: Wed Jun 03, 2015 8:03 pm
My tee didnt make a week after it was rebuilt before it snaped off and left a trail of oil through the carpark
Post Posted: Tue Jun 09, 2015 12:11 pm
Braided hose and the tee mounted on the firewall/guard etc solve that issue?
Post Posted: Tue Jun 09, 2015 12:32 pm
Definitely. Any method that removes the weight from the block so the brass threads aren't affected by fatigue should resolve the problem.
Vehicle: 2007, GV, trekker
Post Posted: Tue Jun 09, 2015 7:16 pm
hows this build going?
Any more pictures?
Really wanna hear this thing spool up and run.
Post Posted: Fri Dec 25, 2015 11:11 am
Awesome pics mate, looks really nice. Updates please.
Vehicle: Vitara 1994
Post Posted: Mon Feb 22, 2016 9:36 pm
Serious question. Why? what is the weak point of these engines? the 9.5 stock comp looks to be fine with modern tuning and fuels. How strong are the rods?
Vehicle: Suzuki Grand Vitara
Post Posted: Thu Mar 22, 2018 1:07 pm
How did the build end up could the person please message me
Vehicle: 89 sierra
Post Posted: Fri Mar 20, 2020 6:51 am
I know this is pulling up a really old thread but I'm pretty sure I just bought this car. I know it's a really long shot but did anyone ever talk to this guy?
Post Posted: Thu Nov 18, 2021 7:07 am
I didn't talk to him but found pictures and info of the build since the start
Post Posted: Thu Nov 18, 2021 7:11 am
Vehicle: 2000 Tracker
Post Posted: Sat Dec 18, 2021 11:53 am
Zukikrawler at Zuks of Arizona is 99% done with his, just tuning now.
